Turn Signal Relay Fuse (solved)
Old Jan 10, 2015 | 10:41 AM
Chris09's Avatar
Default Turn Signal Relay Fuse (solved)
I have a stock 93 Honda Del Sol si 1.6. The turning signals don't work at all and the signal relay fuse doesn't click at all. I wanted to test it first before trying to replace the switch which is very costly for me right now. I prefer diagnosing first instead of just replacing parts.
Which relay fuses can I use temporarily in place of the turn signal relay fuse to test it? I don't want to use one that would mess any other function up.
Old Jan 10, 2015 | 10:44 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default re: Turn Signal Relay Fuse (solved)
it's called a turn signal relay, do you signals light up but don't blink? they go bad all the time not a very expensive part
Old Jan 10, 2015 | 10:47 AM
1985-2002, 2005-2006 Honda Civic Turn Signal Relay - Body Electrical - Standard Motor Products 85-02, 05-06 Civic Turn Signal Relay - 5997-07087724 - PartsGeek
Old Jan 10, 2015 | 10:55 AM
Chris09's Avatar
They don't light up at all, but my hazards and everything else works. Thanks for the response.
Old Jan 10, 2015 | 11:30 AM
check your fuses, It's doubtful that both sides of the turn signal switch in the combination switch failed at the same time, could also be the flasher unit blew a fuse, order one swap it in, if it's not the issue, you have a spare, which you should have anyway, along with a few spare bulbs
Old Jan 10, 2015 | 12:11 PM
Former User's Avatar
There's a specific fuse for the turn signals in the dash fuse box.
Old Jan 10, 2015 | 03:29 PM
Chris09's Avatar
I figured it out. It was a wire connector that was starting to wiggle its way loose in the fuse box.
Old Jun 9, 2022 | 08:05 PM
mycky's Avatar
Default Re: Turn Signal Relay Fuse (solved)
However, there is also a fuse #43 in the fuse box in the engine compartment. And this one needs to be working for the other fuse to complete a circuit.
Albondigas XXG
Honda Civic (2001 - 2005)
Aug 28, 2015 06:15 AM
stops
Lighting
Jun 8, 2015 06:24 AM
Paul 631
Dec 25, 2011 07:19 AM
gnxpro24
Feb 2, 2011 03:52 PM
courtney42
Feb 16, 2009 02:33 PM
