MPFI intake question
Old Jan 8, 2015 | 05:24 PM
NickH93's Avatar
Default MPFI intake question
I have a D15B2 DPFI setup, 89 DX.
I was told you could use a D15B7 intake for the MPFI swap so I bought one since the price was right. After the fact, i realized that these were from OBD1 set ups. If I have OBD1 injectors, do I just keep them in my OBD0 setup (PM6) just with no resistor box?
Also, being from an OBD1 system, will I have any sort of connecters on the intake that my obd0 DPFI won't have?
Thanks
Old Jan 8, 2015 | 06:10 PM
jonGSR's Avatar
Default Re: MPFI intake question
Are you converting to obd1? If not you cannot use the injectors. You will need the obd0 injectors with the resistor box.
The manifold will work fine though.
Old Jan 8, 2015 | 06:12 PM
jonGSR's Avatar
Forgot to add, all the plugs you need are already on your harness with the exception of the injectors and resistor box plug. You'll need to probably lengthen the TPS, IAT,and EACV wires. I usually lengthen those 3 to give me enough room to move them around when removing the oil filter.
Old Jan 8, 2015 | 07:36 PM
24TEN's Avatar
PHANTOM MENACE
Injectors are independent of OBD configuration. The conversion process to run those injectors is covered in the FAQ. As for that manifold you can use it but you'll need a throttle body that matches the flange if it didn't come with the original one.
Old Jan 9, 2015 | 09:30 AM
4drEF's Avatar
Keyboard Humorist
^^ this!
Just reiterating to make it clear that you can use either style injector.
There is no such thing as an OBD0, OBD1, or OBD2 injector.
If the flow rate is correct, you can use it.
They are either 'peak and hold' type or 'saturated' type - one is 'low impedance' and requires a resistor box.
Old Jan 9, 2015 | 11:18 AM
NickH93's Avatar
Pretty sure mine are high impedance. Thanks for the help guys, and thanks for bearing with my constant questions. I'm gonna hit up a local junkyard tomorrow and find me some injector plugs and distributor.
Old Jan 10, 2015 | 02:01 PM
NickH93's Avatar
Sorry for my constant questions. I found some injector plugs at a junk yard off an Accord. I modified my clips to fit (I've confirmed my injectors are high impedance.)
I seem to be getting some conflicting info, all wire colours aside, which injector is #1? Towards the distributor, or opposite?
Old Jan 10, 2015 | 03:36 PM
24TEN's Avatar
PHANTOM MENACE
#1 cylinder will always be closest to the timing belt regardless of engine.
surkitroller
Dec 29, 2009 12:58 PM
lilsicsoul
Mar 1, 2009 04:23 AM
atarigamer01
13
May 20, 2008 09:23 AM
nucivowner
Mar 11, 2005 11:33 AM
dpine
Jul 14, 2004 06:19 PM
