Acceleration / Cruising Stutter help
Old Jan 8, 2015 | 01:08 PM
Austin's Avatar
Icon6 Acceleration / Cruising Stutter help
I'm the original owner of the car, this problem started on Tuesday morning on my way to work, and I haven't been able to find the problem, so a little help would be appreciated.
2001 Type-R
Wiseco ~12:1
Stock Cams
290cc/min injectors(‘97+ Prelude)
HyTech Header & Exhaust with Cat
Hondata S300
J&S Safeguard
vtec is set to 3750
Problem:
Idles fine
Free Reving is slow to respond
Acceleration is really slow in the lower RPM ranges, as it passes through 2500-3500rpm you have some stuttering, when you go over the vtec switch point it gets slightly better, over ~4500 rpm is still slow acceleration, but the car doesn’t stutter.
Cruising at low throttle %, when you have a low load on the engine, slow rev, no stuttering. When you increase the load, the stuttering/bucking is apparent. When you go past ~4500 rpm you have no stuttering/bucking, cruises fine.
Things that we’ve already tried that haven’t changed anything:
Rotor/Distributor Cap
Plugs
Swapped the Distributor with a known good distributor
Reinstalled OEM 240cc/min injectors
changed vtec switch to 3000 rpm
Things to try tonight:
“fresh” Hondata B18C5 program
OEM Ecu reinstallation
Old Jan 8, 2015 | 02:15 PM
wego5typer#431's Avatar
Default Re: Acceleration / Cruising Stutter help
Have you checked your TPS sensor?
Old Jan 8, 2015 | 02:25 PM
Austin's Avatar
I looked at the throttle % via Hondata, and also looked at the TPS logs, they looked good. I'll review them again when I return home to see if I might have missed something.
Old Jan 9, 2015 | 01:51 PM
HAMOTORSPORTS's Avatar
Try disabling closed loop and retest. It sounds like an O2 feedback problem (either faulty O2 sensor or wiring).
Old Jan 9, 2015 | 08:24 PM
purplepassiongsr's Avatar
X2 tps sensor. Test you voltages with a multimeter.
Old Jan 10, 2015 | 09:29 AM
tamboo's Avatar
10 Year Member
tested plug wires? checked cam alignment?
fuel pump gave me some stutter when it was on the way out.
dorman tps ftw, f u blox! 8(
Old Jan 10, 2015 | 11:26 AM
Austin's Avatar
Update - problem still here, items that I've since tried:
TPS readings - fine, across the entire sweep of it's movement from 0% throttle to 100% thottle, viewed while at a standstill, then datalogged a 5 minute drive via Hondata, both show good numbers.
O2 sensor - went from Closed Loop to Open loop, slightly better idle, but no change in driveability...even after resetting the ECU short/long term fuel trim.
Hondata Program - used their '01 itr program, no change.
ECU - swapped in the OEM ECU, slightly better drive ability(tells me that I need to redo my tune), still have the stutter. Codes 65(no secondary O2 sensor equipped), Code 1(primary O2 sensor must be bad, but I can turn it off in Hondata for now)
J&S Safeguard - removed when swapping to the OEM ECU, as it's connected to the OBD2b-->OBDI harness adapter.
Old Jan 10, 2015 | 06:17 PM
I would still check your TPS sensor with a multimeter for proper voltage, another thing to check is your MAP sensor
Old Jan 10, 2015 | 08:59 PM
wunfstgsr's Avatar
Loved
Community Favorite
MAp sensor failure.
Jonathen Lee
Sep 11, 2018 03:02 PM
viperjng
28
Aug 18, 2011 07:16 PM
fv8s
Dec 4, 2010 02:10 PM
ieatrice
Dec 1, 2008 04:18 PM
Woogie Ctr
Apr 11, 2006 03:08 PM
