gsr with type-r internals on stock p73 ecu?
Old Jan 5, 2015 | 09:26 PM
raverx3m's Avatar
Default gsr with type-r internals on stock p73 ecu?
i want to keep the matching vin tags on the engine
If i swapped complete itr internals into the block and head and used first gen blox manifold
Would i be able to run it properly with stock usdm itr ecu
Old Jan 6, 2015 | 07:52 AM
bspeed's Avatar
Default Re: gsr with type-r internals on stock p73 ecu?
Yes. Running a p73 right now on gsr with ITR guts on a SK2 Ultra street, works great until I upgrade to a standalone.
Old Jan 6, 2015 | 09:35 AM
raverx3m's Avatar
have you actually ran it with a wideband?
how do you tell it runs great?
because ive seen people say gsr runs great with stock b16 ecu... and even b16s running"good" with stock p28
Old Jan 6, 2015 | 10:28 AM
bspeed's Avatar
No wideband, but not butt dyno either. I have ran it on an obd2 b16,gsr and now type r ecu. Smoothest throttle, idle, cruise of all was with p73. I know it runs a little rich due to fuel consumption (280 tank vs 300 on p2t) It makes the more power because I can drive up my hill in 4th where I was stuck between high rpms in 3rd or gutless 4th on p72 ecu. So while not entirely scientific, all of my subjective results have been repeatable.
Running oem injectors with oem parts, oem ecu is fine for now.
Old Jan 6, 2015 | 11:28 AM
raverx3m's Avatar
im looking for someone with a wideband to confirm please.
Old Jan 6, 2015 | 02:01 PM
blackeg's Avatar
bump would like to know too. i have a friend who is about to to the same thing.
Old Jan 6, 2015 | 07:33 PM
raverx3m's Avatar
Technically the only difference is the runner angle and combustion chamber on gsr head.
I just have a feeling that it might have lean/rich spots throughout the higher rpm
and maybe alot of fuel trim in closed loop
Old Feb 10, 2015 | 02:56 PM
blackeg's Avatar
u give this a try yet? my friend just picked up a cdm p73.
as said i bet you could mess with fuel pressure just a tiny bit and get it to work reasonably....
Old Feb 10, 2015 | 05:53 PM
raverx3m's Avatar
No not yet. But im thinking it should be ok
Old Feb 11, 2015 | 03:04 AM
blackeg's Avatar
yeah I'm thinking the same. let me know how it turns out
Old Feb 11, 2015 | 04:38 AM
LTCxD2B's Avatar
U need to use the itr Ecu ... It runs richer because of the higher compression the itr runs so u have a safe Zone ... Either way u should not go ham on it till u get a real tune
Old Feb 11, 2015 | 07:53 AM
blackeg's Avatar
it is an itr for all purposes. type r pistons and cams just in a c1 block not a c5 block
Old Feb 11, 2015 | 02:04 PM
LTCxD2B's Avatar
Gsr head design is different and gives a higher compression when using itr pistons if u had a b16 head then u would just have an itr really
Old Feb 11, 2015 | 04:15 PM
blackeg's Avatar
ok, like ******* .2 of a compression point. knock back the distributor .5 degrees to compensate which the knock sensor will do anyway if it knocks. conversely, the quench on the gsr head is a better design...
Old Feb 11, 2015 | 07:37 PM
raverx3m's Avatar
that's what my main concern is the quench area and port angle but I guess ill be the first one lol
I was hoping to find someone who done it and tested it
I have everything to tune the car. so if anyone has done it and wants to street tune it with wideband ill be willing to do that just to test. seattle area
compression is not a problem to match with thicker headgasket
or by using jdm gsr pistons
Old Feb 12, 2015 | 12:11 PM
LTCxD2B's Avatar
I wouldn't worry about trying to match compression just understand that it's different so when u tune take that into consideration
Old Feb 12, 2015 | 01:13 PM
raverx3m's Avatar
Read original post i dont think u understanding why im asking this question
langjairicer
Aug 7, 2010 05:18 PM
BOOSTEd2
Feb 7, 2010 10:56 AM
so simple
Apr 12, 2009 08:31 PM
gsrjdm00
Dec 30, 2008 11:32 AM
gsrXredline
Dec 15, 2002 03:14 AM
