wire diagram for 89 trunk glass heater
Old Jan 5, 2015 | 09:26 AM
cast.aluminum's Avatar
Default wire diagram for 89 trunk glass heater
Could anyone point me in the right direction on how to wire my fuel pump switch. I'm trying to make the the glass heater switch (in my 89 si, it's just right of the steering wheel and has an orange light) into my fuel prime switch..would anyone know which wire (cuz its a 5 or 6 wire switch) is the power wire and if this switch is a 12v switch? I would really appreciate some well thought advice. Thanks
Old Jan 5, 2015 | 07:53 PM
Default Re: wire diagram for 89 trunk glass heater
Bump
Old Jan 5, 2015 | 07:54 PM
Anyone? Basically, i want the trunk glass heater switch to be a manual fuel pump switch
Old Jan 5, 2015 | 07:55 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
you know that circuit is a timed circuit right? why would you be trying to use this switch, why not just ad one?
Old Jan 6, 2015 | 09:10 PM
I wasn't exactly aware of that. I just figured that as long as the glass heater was depressed and the little orange light on the switch is live..
Old Jan 7, 2015 | 11:47 AM
Bump
Old Jan 7, 2015 | 12:26 PM
4drEF's Avatar
Keyboard Humorist
Why are you bumping?
If you press the switch, it automatically turns itself off after a set amount of time.
I'm not sure how it works, but this isn't the first time that I have read that it may have a timer in it.
Open it up and check it out!
Old Jan 7, 2015 | 04:30 PM
there is a timer module and relay somewhere, it varies depending on which model, the switch only controls the relay, the rear glass heater takes a lot of current, so the switch doesn't directly control it
Ldo
10
Feb 24, 2009 05:15 PM
turbo-crx
Jan 9, 2009 09:58 AM
civicexowner
Dec 22, 2007 04:04 PM
99fbpem1
Audio / Security / Video
Aug 19, 2007 04:23 PM
Simple
13
Jan 10, 2004 07:57 AM
