1999 Accord LX code 1457
Old Jan 4, 2015 | 02:21 PM
rdone's Avatar
Icon2 1999 Accord LX code 1457
I searched the forum before posting this and didn't find what I was looking for.
For quite a while I've had the 1457 code. I took it to the dealer and they replaced the part that is usually the problem per Service Bulletins 01-011 and 03-001. Of course, the code came back after a while. I tested the new part and can activate it with voltage. I don't know if the replaced part was bad.
Besides checking for a leak somewhere in the lines, is there anything else it could be that I could check out? Can the canister itself go bad and how would I test for that? It's not driven in a corrosive environment and there is no corrosion.
Old Jan 5, 2015 | 04:57 PM
Lost Again's Avatar
Default Re: 1999 Accord LX code 1457
Look for posts from "phootbag" on this subject. Way more info from him on this than you'll ever want to know.
There are two valves - too lazy to look, a vent and a shut - and then add that yes the canister can have damage. There are the lines that can leak....and believe this or not, even spider webs can cause an issue,,,yes there is a kit from honda to revent spiders from getting in there and building a web.
tknep
Nov 2, 2016 05:00 AM
GnatBee
Sep 1, 2012 11:04 AM
BigDanTFM
Jun 8, 2012 08:46 AM
tjhogg1
Feb 14, 2007 07:32 AM
