Radio reception gets static when 12v aux plug is in use
Old Jan 4, 2015 | 01:53 PM
Sp0008's Avatar
Default Radio reception gets static when 12v aux plug is in use
2002 Honda accord coupe EX. Original Radio works fine until I plug a charger into the 12v auxillary plug.....then the radio gets static. Pull the charger out.....radio then works fine. Any ideas as to what may be causing this? Thanks in advance.
Old Jan 4, 2015 | 05:40 PM
chrisnick's Avatar
Default Re: Radio reception gets static when 12v aux plug is in use
Poor grounding.
Old Jan 5, 2015 | 08:44 AM
Sp0008's Avatar
Thanks for the reply. So now, how do i go about correcting this 'poor grounding' issue. thank you.
Old Jan 5, 2015 | 04:27 PM
chrisnick's Avatar
Replace chassis grounds with well shielded, larger gauge wires. Clean all grounding points so they have good positive contact between the ends and bare mounting points. Ensure your radio's ground is in good shape, too.
aalb1
Audio / Security / Video
Jun 30, 2009 12:05 PM
JHP
13
Mar 9, 2009 12:20 PM
JHP
Mar 9, 2009 02:57 AM
chuckbower
Jan 25, 2007 07:22 PM
coolrace05
Nov 1, 2005 03:38 PM
