98 Civic ex, Car wont rev past 5k
What do you consider basic? I have to assume things i do not know.
If you have checked the basics post what you checked. I am not a mind reader nor anyone else. Anything you have checked should be in your first post
Have you cleaned the vtec solenoid screen?
Wires all good?
Wires all good?
i have cleaned screen, what i believe to be the pressure switch(what the vtec noid is mounted to) throttle body, cleared codes and test drove multiple time throws same codes. dizzy is good plugs and wires are too, im a lost chevy guy that works a ford with a screwed honda lol
alright, thanks for the help im going to check the connections and if theyre good im going to replace the knock, if that doesnt fix it ill hit you up again
thanks much again
thanks much again
What engine do you have? Is it a D16Y8? Post the block and head codes.
https://honda-tech.com/honda-civic-d.../#post48684945
my problem isnt always a problem, sometimes if its doing it ill put it in neutral torn it off and start it again and i can go over 5k/ hit vtec for a min then it does it again
Bj Bennett
Honda Civic (2001 - 2005)
Dec 16, 2015 04:31 AM
ntoxicatedtigah
Jun 24, 2009 02:56 PM
ninety9ex
Jan 26, 2004 07:40 PM
