98 Civic Hatchback Rust Question
Old Jan 3, 2015 | 03:21 PM
schen028's Avatar
Default 98 Civic Hatchback Rust Question
98 Ek Hatchback recently purchased. I've been talking to a couple automotive body shops that would cut the metal out and put a new piece in. Overall the car is in very good shape, no trunk rust, frame rot just the small hole in the rear passenger side quarter panel.
Would this be a very easy process to fix for an automotive body shop or should I keep the car as is?
Old Jan 3, 2015 | 03:23 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 98 Civic Hatchback Rust Question
Wait. Did you not say you were talking to shops? What did they tell you?
Old Jan 3, 2015 | 03:42 PM
schen028's Avatar
Correct, soonest appointment i have is Monday. I just don't know if it's worth it or not.
Old Jan 3, 2015 | 03:46 PM
The Grumpiest
Won't you find that out when you get the estimates? And what shop cannot give you an estimate right there on the spot? Unless you're only talking to these people over the phone.
This should be in the Paint & Body section. Not tech.
Old Jan 3, 2015 | 06:21 PM
92ehatch's Avatar
Body work. Done correctly, is expensive.
This is an opinionated thread. My opinion and your opinion of worth is different.
Old Jan 3, 2015 | 06:23 PM
The Grumpiest
Oh, if you think that's all there is you're probably mistaken. Rust is like an iceberg.
Old Jan 3, 2015 | 06:38 PM
schen028's Avatar
How expensive? like a $1-$2000?
Old Jan 3, 2015 | 07:13 PM
ek9_beast's Avatar
Your asking a question nobody has the answer to without being with the car. What you can see in that pic, once you start getting into it will be 5 times that size if not more. If it's rusting there, it's probably rusting around the rear of the wheelwell as well. Basically the rust you see is small compared to what is under that panel. If you plan on keeping the car, fix it and paint it. If its just a daily, run it til it dies because ur front bumper needs replaced/painted as well as the grill needs paint. Good luck, gotta start somewhere
Team Loyalty
Jul 21, 2018 07:58 PM
jonsey1886
Nov 11, 2016 09:30 PM
Manny07
Jun 18, 2015 05:33 AM
matt98hb
Nov 15, 2003 05:22 AM
Nothing.Special
Jun 1, 2003 01:46 PM
