93 Del Sol Parasitic Draw
Old Jan 2, 2015 | 03:08 PM
marcelosm's Avatar
Default 93 Del Sol Parasitic Draw
Hey guys, I have been having problems with my battery draining overnight while the car just sits there. I had the battery checked by Autozone and the battery is good. If I use the car every day the battery never dies but if I leave it sitting for 2 days then it will die.
While trying to figure out my problem I came across an ericthecarguy video about parasitic draws and it seemed to fit my problem perfectly so I used my volt meter the way he instructed and I was seeing a .20 amp draw on my battery which is much higher than the acceptable 50 milliamp draw (according to the video).
So I got to pulling fuses and found that in the under dash fuse box, fuse number 3 (7.5) was causing the issues. That fuse was for the integrated control unit, the ceiling light,. trunk light, and data link connector.
I am not really sure where to go from here though because in his video it just ended up being a switch that was left on. Does anyone have any suggestions?
Thank you!
Old Jan 2, 2015 | 04:31 PM
Former User's Avatar
Default Re: 93 Del Sol Parasitic Draw
Is the draw eliminated by unplugging the ICU?
Did you do any mods prior to this problem?
Old Jan 2, 2015 | 05:49 PM
EsotericImage's Avatar
Retired Moderator
Mine does the same thing..
A while ago i smelled an electrical burn for a moment. Then i find that my dome light stays on in the door setting. I just havent gotten around to fix it. I remember it used to have dimming when the doors closed.. now it just stays lit.
So if you find the cause post it up here.
Old Jan 2, 2015 | 06:08 PM
marcelosm's Avatar
No, no mods where done to the vehicle and actually this started pretty much out of nowhere. I hadn't made any changes i remember of when this started happening. I haven't tried unplugging it and honestly I don't even know what it does. Unplugging the fuse fixed stopped the draw though. I wouldn't mind not having the dome light or the trunk light but I don't know how not having the icu would affect the vehicle.
Old Jan 2, 2015 | 07:16 PM
belairbrian's Avatar
icu controls intermittent wipers, headlight chime, and I think hi-low switching for headlights.
Old Jan 3, 2015 | 03:55 AM
delsolintegra's Avatar
I had a bad ICU in a 94 del sol. I went to a junkyard and pried another one off of the back of a fuse box. I opened the old one up just for curiosity and the circuit board had burn marks on it. It was draining my battery too.
Old Jan 3, 2015 | 07:45 AM
marcelosm's Avatar
Just to be on the safe side, where is the switch that indicates if the trunk is closed or not. Before pulling out the ICU wouldn't it be smart to check if the trunk light is turning off?
Old Jan 3, 2015 | 11:29 AM
Or just remove the bulb to see whether the drain is eliminated.
Old Jan 3, 2015 | 04:04 PM
marcelosm's Avatar
Yeah, that works too. I will update ASAP.
Old Jan 4, 2015 | 03:31 PM
marcelosm's Avatar
I pulled the light from the trunk and I am no longer getting a reading on the multimeter so I think that was the culprit. I don't mind not having a light in the trunk since it didn't help much to begin with anyway. Thanks for the help.
smileyltu75
Apr 13, 2013 08:51 AM
rSol93
13
Dec 28, 2008 07:30 PM
90goldhatch
24
Feb 28, 2008 06:57 PM
RemoveGiantWingOnYourCar
Nov 3, 2006 08:04 AM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
