96 fog lights wiring help
I've been looking online but haven't found an answer yet (could be tired) but I am looking to wire my fogs directly into my parking lights. Harness is in and fogs are in. What I'm left with is one yellow wire with a female plug on it. From what I've found is that not my fog power wire? So if it is then can I not just tie it into my parking lights power and be done?
Yellow wire with a female plug. Not sure but most the time male goes to female.
But anymore the world is changing....
You see the important information missing from your post? Haven't the damndist what wire you have what kit you have etc
civics have an optional output for park lights on the fuse panel
option 3 i believe. you need a 15 amp inline fuse.
you need 12v (red) plugged into fuse panel and yellow should be ground.
where did you supply your 12v from?
Blaxican707
Nov 23, 2005 07:24 PM
