92 Civic SI - No crank, no start
My 92 Civic SI won't crank. Lights come on, battery is charged and the alternator is working. Replaced the starter and still same problem. Was able to push start it and it drove fine. No problems before this.
Any thoughts?
Any thoughts?
check your grounds also. I had the same issue and once I fixed my ground it would start right up. cranking your engine takes alot more juice than turning on your headlights.
Nov 15, 2010 08:34 PM
