95 Civic - Fuel pump won't prime (got rid of car)
im having issues where my main relay is good and my fuel pump works. When i turn the key on it will not turn the fuel pump on. I put my relay in my friends civic and it worked. I used a jump wire to 1 & 7 and the fuel pump comes on. I see this is a common issue in 90's model hondas. i have a 95 civic Dx. Any help?
just tried it fuel pump kicked on, ecu ground looks good. i had the issue where it seemed like the main relay was going out. Taking a while for the fuel pump to kick on now it doesn't at all
Turn key to ON(II) and then ground terminal A7 or A8 in the ECU connector. Does the pump run everytime you ground the terminal?
ok i unplugged A terminal on the ecu. put my jumper wire inside the plug where the yellow green wire is and turned the key on nothing happened . Opened the ecu and it has a burnt spot on the motherboard
I believe you finally managed to do Ron's test correctly by finding the Green/Yellow wire which I am thinking confirms it being the ECU.
With the popped cap in the ECU, you could try replacing the capacitor and see if the ECU is still good and if it fixes your issue.
Ron may have more tests to verify things even though it looks pretty cut and dry with your recent discovery.
