B18C5 Block N/A setup Rebuild Help.
Old Dec 30, 2014 | 08:38 AM
Z0831xiz's Avatar
Default B18C5 Block N/A setup Rebuild Help.
Hello guys I have a few questions of advice i been needing and im sure onky true 'R' enthusiasts can answer it.
Please answer them numbered! Much appreciated.
1 how much does a B18C bare block go for (as pictured) only comes with the 'ITR' Crank that spun #3 bearing.
2 what should i consider in mind if the Block doesnt have the Vin number attached to it.
3 what should i do if i buy a Block like this with a possible bad crank? Try to repair it or replace it with another crank.
4 how good and worth it is it install a Ls (B18B1/A1) crank into a B18C5 & what rods/pistons have some of you used of heard of useing.
Old Dec 30, 2014 | 08:43 AM
Z0831xiz's Avatar
Default Re: B18C5 Block N/A setup Rebuild Help.
This is the Block thats being sold to me.
It comes with the main caps & griddle
Old Jan 1, 2015 | 11:47 PM
CW-ITR's Avatar
_$200-$250 for one that need to bore out or re-sleeve. $250-$400 for a good one. The spun bearing crank is pretty much junk.
_For a B18C5, no VIN means it is considered "hot" until proven innocence.
_See answer #1.
_The answer is totally depend on what you want to do with this block
Old Jan 2, 2015 | 03:34 AM
Runnerdown's Avatar
C5 with no VIN, 99% chance it's stolen. If it a greasy oem finish there is no reason to remove it. If it was polished, power coated etc then it may have been removed. But still should have been reinstalled.
labatt50
Sep 24, 2006 12:28 PM
ninetail
Apr 3, 2006 12:58 PM
Topdawgg
Jan 5, 2006 06:32 PM
BlkSIvic
Dec 25, 2003 08:54 PM
