How best to cut and bevel weld elbows?
Old Dec 29, 2014 | 01:58 AM
G19doug's Avatar
Default How best to cut and bevel weld elbows?
So I've been making a few manifolds. Currently I cut the stainless weld elbows with a 1mm cutting disk on a hand grinder and then swap to a 60 grit flap disc to put the bevel on.
Is there a more consistent and quicker way of doing this?
Do most people use an abrasive chop saw? Or perhaps a horizontal band saw? Which cuts straighter? How long does the blade last cutting stainless?
And is there a better way to put the bevel on?
Any advice appreciated.
Doug.
Old Dec 29, 2014 | 09:26 AM
98vtec's Avatar
moderator emeritus
Default Re: How best to cut and bevel weld elbows?
Doug.
Depends on how deep your pockets are. I could not imagine making a manifold with hand cut pieces.
I use a chop saw because its cheap plus the cutting wheels are cheap and readily available almost anywhere.
step up to a band saw which is a little slower cut but doesnt have near the clean up but with a much higher cost from a chop saw.
then there is a cold saw which doesnt have large amounts of clean up either but the cost of a cold saw is pretty large.
all depends on how often you make a manifold and how much money you can afford to put towards shop tools.
Old Dec 29, 2014 | 10:44 AM
kingofbattle909's Avatar
Port-a-band with a stand does the trick but is more for flat pieces IMHO. (I have one)
The little band saws will also do the trick for a little extra coin.
If "cutting time" is an issue for you, I'd go with a chop saw that will allow you to fit one of thee Carbide Tipped Circular Saw Blade (Milwuakee is my pers pref)
^These blades are NOT cheap but will last a long time.
Old Dec 29, 2014 | 07:11 PM
itspools's Avatar
I built my first couple of manifolds with a chop saw. Still not sure how i never lost a finger. But then I started using a 20 year old band saw that kept my fingers safe but took 10 mins to cut a piece of schedule 10.
Finally I said **** it and bought this:
Grizzly.comŽ --
I love it and it use it for everything I can.
Not cheap, but time is money.
I use a Porter Cable sander from Lowes to bevel the edges and a Northern Tool bench grinder with a wire wheel to polish. I plan to upgrade the Norther Tool unit after the new year.
PTPbracket
Welding / Fabrication
Nov 18, 2008 09:12 AM
Civic-Kids
Paint and Body
Oct 7, 2007 06:41 PM
Jonathan_ED3
Feb 7, 2007 04:51 PM
Tigfab
Aug 21, 2006 05:17 AM
Fred Allen Burge
May 2, 2006 11:04 PM
