ignition timing and hondata s300.. help required
good day
Engine : JDM b16a stock head and block
ECU : hondata s300
With the stock cams I had no issues setting the ignition timing as per ( select set timing enter 16 degrees and adjust the dizzy to suite)
I have installed dual valve springs and replaced the cams the exhaust is +2 and -2 intake.
I am unable to set the timing to 16 now.
I found some info not sure if it was correct.
1 cam degree = 2 crank degrees.
Therefore I set ( the set timing in hondata to 20 degrees ) and in doing that the crank lines up with 16 degrees.
Is this correct . If not please advise.
thanks for the help
ECU : hondata s300
thanks for the help
I have never used Hondata, but if you changed the cam timing on the intake camshaft you will need to adjust it back with the distributor. There should be an option to lock base timing with the S300, you will want to set it back to 16 degrees with the distributor with the timing locked. I wouldn't recommend compensating with the timing like you have.
JDMlyfestyle
23
May 19, 2008 05:52 PM
Please Help Hondata Users. Please tell me how to synchronize romeditor timing to distributor timing.
TypeR76
Jun 9, 2003 09:07 AM
