Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
injectors not firing?
Old Dec 27, 2014 | 04:23 PM
xsianthracite's Avatar
Default injectors not firing?
I have a 99 acura rl and the injectors are not firing. I checked for power and they are not getting any. What sends power to them that I can check and fix. Thanks.
Old Dec 27, 2014 | 04:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: injectors not firing?
When the ignition is in RUN or START, battery power (+) energize the main relay, allowing the relay contacts to close to supply power (+) to the fuel injectors.
So, essentially, when the ignition is in RUN or START, power (+) should already be on one side of the circuit of the injectors. But, the main relay does not control them. The ECM/PCM control how the injectors operate via the ground (-) side.
Old Dec 27, 2014 | 04:59 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Issue can be due to a fuse or wiring.
Old Dec 27, 2014 | 05:15 PM
I checked all the wiring and pulled every fuse one by one. Im stuck. I was also told that the crank position sensor has something to do with the injectors getting signal to fire. Dont know how true is that. I just need to find the source of the signal soni can try to trace it from where it starys and stops.
motordog
Honda CR-V & Element
11
Dec 21, 2023 10:37 AM
N'viouzEF9
Mar 4, 2011 09:16 AM
ByonSho
May 10, 2010 11:55 PM
dropNdestroyEF
Aug 2, 2007 04:35 AM
brad98_teg
Feb 22, 2006 03:39 PM
