-92, Adhesive for side sill panels and wheel well trim?
Old Dec 26, 2014 | 12:01 AM
user1122's Avatar
Default -92, Adhesive for side sill panels and wheel well trim?
Old Dec 26, 2014 | 08:00 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: -92, Adhesive for side sill panels and wheel well trim?
No adhesive AFAIK.
There are the screws where the front mud guards attach.
About ~10(#27)clips that go up into the sill, from underneath.
About ~10(#30) clips that are hidden behind sill going into the side of the car that hold the sill in place, which I do not think you can see.
Old Jan 3, 2015 | 12:43 PM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by nejmeg
Also, part of the trim is bent (it normally looks like a squashed U, now more like a gaping V in one of the end parts), how to repair this?
It has a metal U channel inside it, if it is opened up and no longer holds shape it most likely is corroded inside and needs replacement.
Old Jan 3, 2015 | 05:16 PM
94 accord typeR's Avatar
just get replacement inner fender trim from the bone yard and use under coating on the inner fender area
IntegraGSR1999
May 31, 2009 04:43 PM
wcontrata
Apr 1, 2009 06:34 AM
93beccalx
Jan 7, 2009 08:16 PM
LankorDie
Jun 8, 2004 02:15 PM
96hb
Aug 21, 2003 10:00 AM
