B18c1 ek no fast idle at cold start until warm
Old Dec 24, 2014 | 07:22 PM
civicguy167's Avatar
Default B18c1 ek no fast idle at cold start until warm
Hey! Im goin round and round with this and havent figured it out. Hoping maybe someone can help a bit. I have a 00 dx hatch with a 96 b18c1with skunk2 intake and tb. Chipped P72 obd1 w conversion harness. Runs off software no o2 sensor hooked up.
My problem is i get no fast idle during cold starts. When i warm it up it starts as it should w the fast idle.
Cold start idles at 600 or just dies if its too cold. Can the iacv stick when cold.. ? Ive tested the plug has power i can hear it when acc is on. Thanks
Old Dec 24, 2014 | 07:35 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: B18c1 ek no fast idle at cold start until warm
Clean out the iacv. Try that?
Old Dec 24, 2014 | 07:38 PM
Yep. Doesnt flucuate.
Old Dec 24, 2014 | 07:44 PM
Thinking out loud here, I need to ground out iacv to test if it will open when cold. I donno if some corrosion in the ecu can cause this or what
Old Dec 26, 2014 | 02:59 PM
hybridmiklo's Avatar
could be the ecu. too rich at cold. I had a similar issue and had to lean out the ecu mapping when cold
civicguy167
15
Dec 3, 2013 08:45 PM
JJexpress
May 19, 2009 03:16 PM
teg racer 877
Sep 28, 2006 01:49 PM
b16vteccx
Mar 22, 2002 06:16 AM
