Fast Idle 2000RPM causes Check Engine = Failed Emmisions Test
Old Dec 21, 2014 | 09:25 PM
CrxChicken's Avatar
Default Fast Idle 2000RPM causes Check Engine = Failed Emmisions Test
Not sure what is causing the problem with my 90 crx dx 1.5 auto
When I go in for inspection they require you to do a 2000 RPM test for emissions which takes about 2 to 3 minutes. You just sit there and fast idle it at about 2000 to 2300 for as long at it takes for the test to happen.
If your check engine comes on then you fail.
If your Emission levels are out of range then you fail.
If I do this in a parking lot the light will come on .. it happens hot or cold.
Thinking it might be the O2sensor since i don't think it has ever been changed.
Don't get an error light other than the Check Engine.
Requires a total shut off / key off.. for the check engine to go away but then it will go away until you try again.
Once off and restarted the engine does not produce a Check Engine under normal conditions.
The Engine does not produce a Check Engine other than every two years when i bring it in for Emissions.. car seems to run fine.
Has a new Cat on it but this happened before and after the cat was replaced.
Been happening for idk 10 years now .. its a drag.
Any ideas?
I am not apposed to replacing the O2 sensor but not if it is working and it seems to be under normal circumstances.
It is not reproducible every time.. maybe every third time .. but it will always happen.
Thanks
Old Dec 22, 2014 | 03:05 AM
mr. Grind's Avatar
Verify what cel ur having first. Ensure its o2 sensor. If it is replace it. if it is something else let us know
Old Dec 22, 2014 | 08:53 PM
CrxChicken's Avatar
Default Re: Fast Idle 2000RPM causes Check Engine = Failed Emmisions Test
its just a standard check engine no blinking
Old Dec 23, 2014 | 04:31 PM
v4lu3s's Avatar
RTFM
If the check engine light comes on it indicates an error code. It doesn't turn on as some sort of standard.
Old Dec 24, 2014 | 02:25 PM
york's Avatar
Check Engine Light = read the blinking LED on your ECU to get the error code.
CrxChicken
May 28, 2015 06:54 PM
tarheels1
Jan 17, 2010 06:38 PM
baulum
Sep 9, 2007 10:39 PM
gtec28
May 18, 2007 07:13 AM
cchev
Jan 23, 2004 04:00 PM
