Honda ACCORD NOT START.. NEED HELP
Old Dec 21, 2014 | 03:00 PM
Howard38's Avatar
Icon2 Honda ACCORD NOT START.. NEED HELP
93 Honda accord 4cyl 2.2 liter. Was driving my Honda on road stopped at stop light. went to give gas engine was not running tried to start car would not start. it will turn over but will not start. check plugs gap ok on plugs. wire seem good. fuel pump is working filter is good battery is ok. Replaced coil pack car still will not start but turns over. I NEED HELP DON'T KNOW WHATS NEXT.
Old Dec 21, 2014 | 03:01 PM
Howard38's Avatar
Default Re: Honda
Old Dec 21, 2014 | 03:05 PM
toker2's Avatar
10 Year Member
Default Re: Honda ACCORD NOT START.. NEED HELP
Timing belt? Open your oil cap, look down in the hole with a flashlight and verify the rocker arms are moving up and down while an assistant turns the key to Start.
Old Dec 21, 2014 | 05:54 PM
nus_dogg's Avatar
^^ That. To verify that the timing belt is still on.
Old Dec 23, 2014 | 11:21 AM
tim73's Avatar
If timing is ok, check crank position sensor.
Old Dec 23, 2014 | 12:50 PM
holmesnmanny's Avatar
Check for spark.
Old Jan 1, 2015 | 09:46 PM
Howard38's Avatar
Icon2 Re: Honda ACCORD NOT START.. NEED HELP
thank u for ur input & yes was a timing belt.. i replace timing car ran find for 30 mins but once she got warm sitting at stop light she starts to act up she wants to die i put her in neutral she acts a little better..i step on gas she spits until she hits at 15 or 20 MPH then she runs fine. timing is set right rpm set at 600. i checked vacuum system by spraying carburetor fluid on every line no change in idle speed. ANY one now what to do?????
Old Jan 2, 2015 | 12:24 AM
Compression test for possible damage.
Old Jan 2, 2015 | 03:46 AM
94 accord typeR's Avatar
Main relay if it works u gotta buy me a beer
Old Jan 2, 2015 | 04:05 AM
tim73's Avatar
If the timing belt broke, compression test needs to be done. Might have a valve slightly belt...leaking a little bit.
SentinelK151
Aug 6, 2017 08:42 AM
Tulga
Feb 22, 2016 07:47 PM
shaney3181
Jul 17, 2009 09:40 AM
