B18C5 Compression?
Old Dec 21, 2014 | 02:52 PM
Ender Ho's Avatar
Default B18C5 Compression?
Can someone tell me what the compression on the USDM ITR B18C5 should be? Not the ratio, but the PSI. From what I understand 135+ is good and less than 85 psi is really bad in general, but I'm not sure if it's different for our engines
Old Dec 21, 2014 | 03:06 PM
blackeg's Avatar
Default Re: B18C5 Compression?
i wouldnt really want anything less than 190 psi. if its not burning any fluids and runs fine id be ok with 190 something. on a perfect motor im sure it would be in the 220 range give or take a bit. 135 has problems.
dont forget proper procedure for the comp test
up to operating temp
disconnect injectors
disconnect distributor
6 cranks, with the throttle wide open
Old Dec 22, 2014 | 12:31 AM
Ender Ho's Avatar
thanks
Old Dec 22, 2014 | 11:32 AM
coolhandluke's Avatar
I wouldn't focus too much on individual numbers. Each compression tester is different. I would focus on the consistent numbers across all four cylinders.
Old Dec 22, 2014 | 08:08 PM
Ender Ho's Avatar
Thanks that's really good advice
Old Dec 23, 2014 | 09:46 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Compression testers and the way the test is carried out differs.
The way I test:
-Cold engine
-Pull the PGM-FI fuse so that the injectors and spark turn off
-Hold throttle open
-Crank till needle stops (try for consistent amount of cranks per cylinder)
I got 220psi with my tester on my JDM B18C (96 spec) engine.
270psi on my JDM B18C (98 spec) with head work
Other relevant cars for reference
240Psi on my stock F20C S2000.
210Psi on my GSR's original B18C1
210Psi on my EM1's original B16A2
I'm fairly sure my tester reads high. But I was looking for consistency and comparison between cars. For example...if my (10.5:1 cr?) B18C was showing a higher Psi than my (10:1 CR) B16A2, which I knew was in good shape...then I was winning.
Old Dec 24, 2014 | 07:15 PM
sportsman1539's Avatar
Compression tests are supposed to be done on a warm engine. Rings need to be expanded to get an accurate reading.
My usdm type r tests at 245-250 on all 4 cylinders.
Freshdot
Aug 17, 2012 01:08 PM
Belarus
Apr 2, 2010 03:01 AM
umair
Dec 7, 2009 10:37 AM
gs-R_swap
Oct 4, 2009 12:12 PM
MrMug3n
Jul 14, 2008 04:02 AM
