91 si motor options
Old Dec 19, 2014 | 05:37 AM
sleeps's Avatar
Default 91 si motor options
New to hondas, have read over the FAQ section, few times.
Other then spending $900 + (from what I can find) for a low-ish milage "JDM" 1.6 engine, are there options for engine replacement equal to or cheaper than the 1.6?
Will very minimal effort that is.
Old Dec 19, 2014 | 08:04 AM
droopy128's Avatar
Default Re: 91 si motor options
Any 1.6 civic to year 99 would fit. Would need to use your intake and exhaust. Plug n play
Old Dec 19, 2014 | 09:39 AM
sleeps's Avatar
Just to be thorough, any 1.6 block and head, using my intake and exhaust, all sensors and ecu will work? What about a d15 black and head from the same year?
Old Dec 19, 2014 | 10:22 AM
24TEN's Avatar
PHANTOM MENACE
Yes it will work. There are small modifications need to certain areas depending on exact engine but nothing you can't overcome with some creativity and/or simple tools.
Old Dec 19, 2014 | 10:34 AM
v4lu3s's Avatar
RTFM
I rebuilt my engine for less than $900. new pistons (pg6b $75), rings(NPR $25), bearings(Clevite $60), then machine shop ($300 for lower end assembly) and a fresh rebuilt head ($60 off local forum), and about $175 in gaskets, seals and pumps. A few more odds and ends and i was right at $900, and so far so great.
Old Dec 19, 2014 | 10:40 AM
testify's Avatar
On vacation
Any 1.6L motor, unless it is a 1.6L out of a 1988-91 Civic/CRX, will be a VTEC motor, and although not that hard, there is some wiring and some pinning on the ECU you will need to do to run VTEC.
The D16A6 in your car is a nice little motor. I'd stick with a rebuilt or remanufactured D16A6 if it were my car.
Old Dec 19, 2014 | 12:59 PM
Todd00's Avatar
I said I don't want a title!
Originally Posted by testify
Any 1.6L motor, unless it is a 1.6L out of a 1988-91 Civic/CRX, will be a VTEC motor...
D16Y7 says you're wrong...
Old Dec 19, 2014 | 02:23 PM
droopy128's Avatar
Here is my DIY of the swap few years back.. still driving it..
Mine is a 4 dr EX thus the 1.6
Motor Swap (D16A6 to D16Y7) - HondaCivicForum.com
Old Dec 22, 2014 | 04:48 AM
sleeps's Avatar
Great, thats good info, thanks.
Old Dec 22, 2014 | 05:19 AM
Marcos Barrios's Avatar
you did that back in 08
congrats ^_^
11
Oct 21, 2014 05:57 AM
2816911965
Oct 16, 2014 07:56 AM
jeffruby
May 25, 2007 05:57 PM
GSRdad
May 27, 2006 03:52 PM
mariopaul
Dec 17, 2002 07:30 AM
