driverside wheel pushed back from accident
Old Dec 18, 2014 | 01:57 PM
BLOCK8732's Avatar
Default driverside wheel pushed back from accident
Wats up HT im having a lil problem putting my EK back together. I had a lil accident and it messed up the front left side of my car. So I was putting the car back together and I noticed the driver side wheel was pushed back and the inner tie rod was bent. I replaced it but the wheel is still pushed back. Everything looks straight to me the other wheel is straight. I have the car on jackstands with the wheels off and steering wheel straight. Passenger wheel is straight but the driver side wheel is turned to the left a lil. When I drove it the car pulled really hard to the left when I let the wheel go. I was wondering if any of you guys have any opinions on this. Thanx all.
Old Dec 18, 2014 | 02:09 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: driverside wheel pushed back from accident
If one wheel is turned out, while the other is straight, then either your tie rods/ends are installed wrong, your tie rods/ends are damaged, or your steering rack is damaged.
Old Dec 18, 2014 | 04:29 PM
92ehatch's Avatar
Get an alignment
Post results of before and after from print out given by alignment tech
Post nothing further until you do that.
Old Dec 19, 2014 | 05:05 PM
BLOCK8732's Avatar
Well alighnment was needed now car doesnt pull to either side it goes straight now. Wheel is still knocked back and it has noticeable negative camber now but car does ride good. No shaking in the wheel or anything
Papalou
Jan 19, 2014 10:40 AM
Corksil
Oct 14, 2009 05:37 PM
Diversion
Aug 27, 2006 02:16 AM
A Blue Lude
May 25, 2006 11:10 AM
A Blue Lude
Nov 1, 2005 11:45 AM
