Trans or clutch problem
Old Dec 17, 2014 | 07:15 PM
Pinkyek's Avatar
Default Trans or clutch problem
97 Honda civic ek
Installed new clutch and new transmission, bled the clutch, will pull for awhile , enough to get down the road and half away back (4 blocks) then nothing,no pulling, no grinding when shift in to gear without clutch.
Has anyone had this problem
Thank you
Old Dec 17, 2014 | 08:05 PM
Former User's Avatar
Default Re: Trans or clutch problem
Problem eventually goes away? Or are you still stuck 2 blocks from home?
Old Dec 18, 2014 | 06:26 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Wow! Posted just in time to enter the contest for "most unclear thread of 2014".
Old Dec 18, 2014 | 11:22 AM
Pinkyek's Avatar
No doesn't go away, sorry about the unclear post was in a hurry.
I've replace both the clutch and transmissions twice, bled the slave both times check the flywheel the last time, the master isn't leaking and the pedal feels good. But it just stops pulling ( it pulled each time after replacing the clutch and strongly pulling) after a few while driving.
Old Dec 18, 2014 | 11:32 AM
B serious's Avatar
What stops pulling? What do you mean pulling?
Old Dec 18, 2014 | 11:35 AM
Pinkyek's Avatar
Feel like the clutch just stops gripping, car doesn't move, and can shift into any gear with out pressing the clutch pedal
Old Dec 18, 2014 | 11:45 AM
B serious's Avatar
Does your clutch pedal have freeplay?
The first half inch or 1" of pedal travel should just be freeplay. The pedal should not push fluid for the first half inch or so.
Your clutch probably doesn't start to engage until the very very top of the pedal travel. Yes?
Set the freeplay correctly and test drive it again.
Old Dec 18, 2014 | 12:13 PM
NotARaCist's Avatar
I never narc'd on nobody!
Also check to make sure your clutch fork is still in position. It would help diagnose if you could look at the clutch fork while a friend pushes the clutch pedal down multiple times. Do you see the clutch fork being pushed by the slave cylinder? Is it moving?
Old Dec 18, 2014 | 12:26 PM
B serious's Avatar
Are you saying to check to see the clutch fork is stuck in the pushed forward position? Like...always disengaging the clutch?
Old Dec 18, 2014 | 12:59 PM
Check the axles.
Old Dec 18, 2014 | 01:04 PM
NotARaCist's Avatar
Well, I was more saying to see if it's engaging at all, but yes, OP would notice that, too.
Old Dec 18, 2014 | 07:25 PM
Pinkyek's Avatar
It was the Rod for the pedal to the master too tight
Old Dec 19, 2014 | 04:18 AM
B serious's Avatar
I'll never get sick of being right 125% of the time.
Old Dec 19, 2014 | 11:02 PM
superspadez's Avatar
Dude. You axle popped out on the pass side Happened to me 3 weeks ago actually lol. Went In to any gear with out using clutch and your speedo moves too when in gear right?? Trust me I'm almost 100% sure
Old Dec 20, 2014 | 07:12 AM
B serious's Avatar
He fixed it....
keiserbikes
Transmission & Drivetrain
Nov 19, 2012 07:26 AM
2fastGSR
Oct 1, 2010 07:39 PM
hatchsi0485
Nov 21, 2005 06:13 AM
tianporn
Nov 5, 2004 12:18 PM
jdmteg95
Dec 17, 2002 03:52 AM
