TRACK EG PARTOUT!!
Old Dec 17, 2014 | 11:38 AM
jdmcivicracer89's Avatar
Default TRACK EG PARTOUT!!
Alright i will post all of the parts that will be parted out off of my hatch. Everything is considered great condition or otherwise noted. I prefer local pickup but will cater to shipping at your expense. Prices r pretty much firm but got alil wiggle room. save the lowballs cuz its not gonna happen. loosing enough cash on this car as it is. no in a crazy rush to sell it all.
TEXT ONLY!! not on here that much anymore 708-717-8221. Located in Orland Park il
1.) Full swap. GSR longblock w/ b16 lsd transmission. Will also include avid motor mounts for eg/dc. GSR wiring harness, short ram intake with AEM filter, 4-2-1 header, blox intake manifold, shift linkage, newer autozone axles, ecu with street tune, purple valvecover. ( Swap has around 30k on it after full oem rebuild by acura. yes i have the paperwork for it. no idea what lsd is inside the transmission but ive never had a issue with it.) - $2200 obo
2.) PCI rear wing with bracket and all hardware. been on the hatch since may. its seen a total of 5 days of sunlight. - SOLD!!
3.) Front splitter w/ brackets and 2 airdams. wood piece is reinforced. it has metal fiber glass and wood layers in it. ***** strong lol. the splitter is mounted to brackets with aluminum bolts that will shear in case of impact. (trust me u want it to break away. ask me how i no haha) - SOLD!!
4.) VIS carbon fiber hood w/ aerocatch hood pins, lockable. hood itself has no cracks but will need a clear coat or really good buff job. - $260
5.) Stance gr+ coilovers, all are revalved to 22k. they have been upgraded to swift springs, 16k front 18k rear spring rates. - SOLD!!
6.) Hardrace front upper control arms. hard rubber bushings. they have only 4 track days on them. - $160
7.) Hardrace rear spherical camber kit. used for only 4 track days - SOLD!!
8.) ASR rear brace (silver) with 22mm rear sway bar and oem endlinks. complete with all hardware - $280
9.) Front ITR brake setup. comes with autozone blanks and hawk hp+ pads. I can also swap knuckles if you are intrested in the arp extended studs. - $220
10.) Rear Goodridge stainless steel lines for gsr rear brake swap. $60
11.) headerback exhaust for eg hatch. cherry bomb resonator to vibrant muffler $100
12.) Mishimoto Aluminum full size dual core radiator with slimfan. - $280
13.) FFD 15x8 +32 rims with nitto nt01 225/45/15 tires. rims are perfect condition. tires are at %50. - $650 obo
Will add more parts when i remember what else is on the car.
Old Dec 19, 2014 | 10:20 AM
Default Re: TRACK EG PARTOUT!!
bump
Old Dec 19, 2014 | 02:49 PM
stdefhatch's Avatar
Wheels are very tempting
Old Dec 25, 2014 | 02:50 PM
bump
Old Jan 9, 2015 | 10:05 AM
stdefhatch's Avatar
Sent you a text earlier
Old Jan 10, 2015 | 09:15 PM
stdefhatch's Avatar
Thanks for the wheels, good seller here
SlaminSohCivic
Dec 6, 2015 04:14 PM
jdmcivicracer89
Dec 26, 2014 02:55 AM
EGfreek
Nov 6, 2008 11:46 AM
kneeslide
12
Oct 7, 2008 11:57 AM
