honda del sol 93 wont move when in gear
Old Dec 17, 2014 | 07:18 AM
hatchet37's Avatar
Icon6 honda del sol 93 wont move when in gear
i have a 93 honda del sol. i was driving it and when i went to down shift i would rev up but not move. so im thinking clutch or transmission problem or fluid is low but i checked the fluid and it is at safe levels. what i dont understand is that while is idling i cant can stick it in gar with out the clutch and it wont die. So pplease help me i need this fixed asap cuz its my daily driver.
Old Dec 17, 2014 | 07:19 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: honda del sol 93 wont move when in gear
So you can engage the gear without the clutch and it does nothing?
Old Dec 17, 2014 | 07:20 AM
hatchet37's Avatar
yes doesnt die or anything so im thinking it could possiably be the linkage??????
Old Dec 17, 2014 | 07:25 AM
09chaplak's Avatar
Loves Tossing Salad
Hmmmmmmmmmm
Old Dec 17, 2014 | 07:37 AM
hatchet37's Avatar
ok so its my clutch cuz that video nailed it. I appreciate your help bud. any tips on changing it.
Old Dec 17, 2014 | 07:49 AM
Former User's Avatar
Check whether an axle popped out of the differential.
Old Dec 17, 2014 | 07:52 AM
hatchet37's Avatar
ronj i did check and it is in. that was the first thing i checked cuz of my bag system.
Old Dec 17, 2014 | 07:55 AM
Sometimes it's easy to miss. The gap between the CV joint and transmission should be relatively small - about 1/8" or so. Post pictures.
Old Dec 17, 2014 | 07:56 AM
hatchet37's Avatar
but that dont explain why it doesnt stall out when in gear
Old Dec 17, 2014 | 07:58 AM
What makes you come to this^ incorrect conclusion?
Old Dec 17, 2014 | 08:04 AM
hatchet37's Avatar
because the clutch isnt disengaging completely
Old Dec 17, 2014 | 08:06 AM
I've seen you post nothing that proves this^ is true. The clutch is disengaged when the pedal is fully depressed.
Old Dec 17, 2014 | 08:11 AM
hatchet37's Avatar
well u see the symptoms what would u suggest
Old Dec 17, 2014 | 08:12 AM
Axle is popped out.
Old Dec 17, 2014 | 08:14 AM
09chaplak's Avatar
Loves Tossing Salad
I think what Ron's saying is that the clutch operation could be completely fine, it's the joint not making correct contact with the trans that is causing the symptoms you are experiencing. Could be the clutch but since you said you don't even have to engage the clutch for the car to not die, it could be the trans is spinning freely and the joint is not making proper connection. So it could be a combo of the two and both should be checked
Old Dec 17, 2014 | 08:15 AM
hatchet37's Avatar
ok n what about it not stalling out
Old Dec 17, 2014 | 08:16 AM
09chaplak's Avatar
Loves Tossing Salad
Just think about how the system works mechanically.
Old Dec 17, 2014 | 08:17 AM
hatchet37's Avatar
the axle is in. and still it doesnt move
Old Dec 17, 2014 | 08:18 AM
You clearly don't understand your car's drivetrain. As I've said, this^ is fully consistent with an axle popping out of the differential.
Old Dec 17, 2014 | 08:19 AM
Post pictures to substantiate. Also note that the axle can break off inside the differential.
Old Dec 17, 2014 | 08:21 AM
hatchet37's Avatar
now that sounds plausable. how much play would be in the axle if it broke off
Old Dec 17, 2014 | 08:23 AM
Everything I've said is plausible because nothing you've posted backs up your claims.
Remove the axle to inspect. Before you do, post pictures of the gap between the CV axle and differential.
Old Dec 17, 2014 | 08:29 AM
hatchet37's Avatar
it is fully inside in this pic
Old Dec 17, 2014 | 10:02 AM
Looks popped out to me.
Where's the picture of the other axle?
Old Dec 17, 2014 | 10:09 AM
09chaplak's Avatar
Loves Tossing Salad
yea dude, even though the pic is small as hell you can still see that it's not butting up where it's supposed to.
