94 Civic CX/D15B8/P05 ECU - Code 41
Old Dec 17, 2014 | 05:53 AM
ruben6805's Avatar
Default 94 Civic CX/D15B8/P05 ECU - Code 41
I replaced the ECU about 1 1/2 years ago with a p05 ecu. I have the d15b8 engine and its giving me this code. is there a resolution?
Old Dec 17, 2014 | 06:21 AM
HAMOTORSPORTS's Avatar
Default Re: Code 41 on a 1994 Civic CX
Not all CX's use a one wire O2 sensor. CA and federal emissions models are different. CA emissions models use a 4 wire (heated) O2 sensor, while federal (49 state) models use a one wire sensor.
If your ECU p/n is 37820-P05-L00, 37820-P05-L01, or 37820-P05-L02 then you have a CA emissions ECU that requires a 4 wire O2 sensor.
Old Dec 17, 2014 | 06:27 AM
Former User's Avatar
Default Re: 94 Civic CX/D15B8/P05 ECU - Code 41
Post a picture of the label on your ECU and a video of the CEL blinking the code.
The P05 does not look for the O2 sensor heater element (code 41) because there isn't one.
EDIT: I was unaware that some D15B8 engines have a 4-wire sensor. Thanks.
OP - Ohm test the O2 sensor and test for voltage and ground on the two heater element wires.
johnwohl
Mar 23, 2009 02:29 PM
CLE
May 28, 2007 10:14 AM
vtec25
Mar 14, 2006 02:39 AM
dfn_doe
Dec 24, 2005 08:09 AM
DreamSpeed
Jan 13, 2002 11:29 PM
