dynamo wrecked
So your Alternator died and you need to get it out. There are 2 ways-from above or below. Either one works but is not as easy as it appears. The upper method means taking the master cylinder off of the booster and moving it over slightly without damaging the lines. The second method requires that you go under the car and take it out from there-after removing both of the alternator mounting brackets.
1- loosen intake manifold and move it sideways, then remove alt from above
2- remove brake master cylinder like someone else said( i dont recomend this)
3- remove axle from drivers side and take it from the bottom.... but u gotta add more oil to tranny afterwards...
too much work ifu dont know what u doing!
I seem to remember taking off the support for my intake manifold and my oil filter and passing behind the engine to the passenger's side where it's nice and easy to remove.
Jizzmaster Zero
16
Dec 21, 2005 02:02 PM
unknownhero16
Dec 27, 2003 05:41 PM
