Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Idle Surging
Old Dec 16, 2014 | 04:22 PM
SeanD13's Avatar
Default Idle Surging
My wife's 2003 Odyssey starting having a surging idle, bouncing between 1000 and 2000 rpm, and generally being a handful to drive on the way home - low on power, uneven, etc.
Here is a video of what it sounds like while parked...
https://drive.google.com/file/d/0B-e...ew?usp=sharing
I have done some research through here, and it seems like it might be the IAC valve, but I really like to know what I'm going after before I start taking things apart in my unheated, non-lighted garage. (Or worse, calling my mechanic.)
Old Dec 21, 2014 | 05:19 AM
WanaBeFaster's Avatar
Default Re: Idle Surging
Is the check engine light on?
Old Dec 22, 2014 | 05:53 AM
SeanD13's Avatar
CEL was on, and at one point the TCS and Maintenance Needed lights were on.
I got the car to the local Advance, scanned the codes - IAC, as well as some old codes from a bad ignition coil this summer. Then, the issue went away. We've got about 200 miles on it since without a hiccup.
A local Honda fella at the store suggested that it might have been low on coolant, or a bubble in the coolant line - since the IAC is near the top of the coolant circuit, it's the first to be affected by low levels.
Old Jan 26, 2015 | 07:21 PM
skinnedknuckles's Avatar
My 1999 Honda Odyssey with 170K miles had this issue, and was fixed when I found a loose vacuum hose. It went to the rear valve cover. I think the hunting was the computer trying to adjust to the problem.
duballstar
Aug 8, 2012 09:54 AM
hon2984
Feb 8, 2008 03:22 PM
street_ride14
May 5, 2007 10:13 PM
Blkteg97
Nov 3, 2004 08:49 PM
Layziebtnh055
Sep 1, 2004 02:38 AM
