HA Motorsports Budget K-Swap ECU $349.00
The HA Motorsports budget friendly K swap ECU is here. This ECU is setup for easy plug and play installation when performing a K series engine swap into 88-00 civic and 90-01 integra chassis. All OBD2 sensor monitors, immobilizer, and multiplex controls are disabled, as well as the fuel, ignition, and cam angle tune is pre-programmed for improved performance over a stock ECU right out of the box!
See the ECU here: HA Motorsports Budget K-Swap ECU
This is the most wallet-friendly ECU solution you will ever find for use with your K-Swap at $349.00
This ECU is designed for use with 05-06 style engine harnesses. If you are using an 02-04 style engine harness, you will also need our K series ECU Jumper Harness so that the ECU will plug into your engine harness.
I'm using an 02-04 RSX transmission. Can I still use this ECU?
Absolutely! We can program the ECU to work with the 02-04 style speed sensor without any further modifications needed. You will not need to install a different speed sensor or do any extra wiring! Simply select your transmission from the drop-down menus when placing your order here: http://www.hamotorsports.com/kswap-ecu.html
Can I have this ECU tuned for my car on a dyno?
Yes. This ECU is setup for use with the KTuner system. The ECU is socketed so that a KTuner dealer board or end-user board can easily be plugged into the ECU and reprogrammed. The ECU can be further tuned/reprogrammed at any KTuner dealer that offers dyno tuning (subject to dealer tuning and reprogramming fees).
Can I upgrade this ECU later?
Yes. If you wish to further upgrade this ECU, all you will need is a KTuner End User System. The KTuner End User System will plug directly into this ECU with no further modifications needed.
Do I need a laptop to use this ECU?
No, the ECU is ready for use as-is. The ECU is pre-programmed to run you engine without any further modifications or programming. Simply plug-in and start your engine.
Have a question? Please don't hesitate to contact us.
1HGEJ2
Engine Management and Tuning
Aug 22, 2017 04:08 PM
mita
Aug 28, 2014 11:46 PM
