94 accord auto to manual transmission swap help
Old Dec 16, 2014 | 07:46 AM
Jack Sleezie's Avatar
Default 94 accord auto to manual transmission swap help
i just did a transmission swap went from auto to manual it worked fine for a few weeks now it feels like me clutch pedal and bracket arfe pushing threw my firewall am I supposed to put a bolt threw the top of my firewall under the wiper motor to the clutch bracket to hold it from flexing
Old Dec 16, 2014 | 02:44 PM
19Accord97's Avatar
Default Re: 94 accord auto to manual transmission swap help
I just finished mine a few weeks ago.
Yes, you need to drill a hole, put a bolt through it and use a sleeve spacer to prevent the assembly from bending. You may need to get a new clutch pedal assembly if it is all bent up or you could bend it back. You'll also want to make sure you waterproof it on the outside so water wont get in to the interior.
Did you put a spacer on the clutch master cylinder threaded studs on the inside of the car as well? I just used two large nuts on each stud that totaled 14mm in length.
Old Dec 16, 2014 | 02:46 PM
19Accord97's Avatar
Those are looking straight up.
Old Dec 16, 2014 | 05:24 PM
yes I did the spacers found that out the hard way but figured it out and thank u for the reply helped a lot thank you
Old Dec 16, 2014 | 06:43 PM
19Accord97's Avatar
Anytime, good luck!
Old Dec 17, 2014 | 11:23 PM
Radial Accord's Avatar
Yeah totally don't forget to use washers to help prevent the cmc from hitting the shock tower, I went and put them on both sides of my firewall just because the holes were drilled by me and not stamped out, no sense in completly hillbilly riggin it. If your holes you drilled to get the cmc into to pedal assembly is sloppy your pedal will be sloppy considering the cmc supports this, maybe you'll put the top bracket on (drilling more holes) for better support, but these will help for a stiffer feel, I still want to get the clutch braket on some day but washers on both sides the fw seem to be working well and their large ones to.
CustomX113
Jul 17, 2006 02:01 PM
Premium Dude
Mar 31, 2006 05:03 PM
supermanvick
Feb 16, 2006 02:58 PM
