I just skimmed through that and it tells you what needs to be done, you need to swap the seat pan, which means no more power seats......didn't you read that?
This chart will list all compatible vehicles for a proven and tested BOLT-ON combination. All other options will fall under the "Seat Pan Swap" category. Now let's put those myths and rumors to rest...
92-95 CIVIC:
-Front-
•92-97 Del Sol
•94-01 Integra
•96-00 Civic w/EG rails
•97-01 Prelude w/EG rails •97-02 Accord Coupe w/EG rails
•01-05 Civic*EM2 Only w/EG rails
•01-03 CL w/EG rails*Requires 12v for heat feature
They should bolt right on... no seat pan swapping required; only the rails from my EG seats.. didn't you read that?
Lots of mudslinging in here. OP you're going to first have to figure out how the Accord seat rails are tied to the power seat feature, if at all. Something tells me they are, since the seats will need to move back and forth on the rails. If they are, can this feature be adapted to the EG rails? Get yourself the wiring diagrams for the Accord power seats, and grok them.
Some EGs in Japan had power seats, too. Here is the wiring diagram for them, this might come in handy.
92-95 CIVIC:
-Front-
•92-97 Del Sol
•94-01 Integra
Scroll down and read further....
edit: well thanks for bolding the text. It states W/EG RAILS. So no you can't keep the accord rails because the motor is using them.
