Accord Coupe Seats (2001) In EG
According to this guide: FAQ: Honda/Acura Seat Compatibility and DIY Seat Pan Swap...EDUCATE YOURSELF!
Accord coupe seats fit with no problem. 92-95 CIVIC: -Front- •92-97 Del Sol •94-01 Integra •96-00 Civic w/EG rails •97-01 Prelude w/EG rails •97-02 Accord Coupe w/EG rails •01-05 Civic*EM2 Only w/EG rails •01-03 CL w/EG rails*Requires 12v for heat feature The drivers seat from the accord are powered and the passengers seat are manual. How do I get the powered seat to work in my coupe? |
Re: Accord Coupe Seats (2001) In EG
Uh, wire it up?
Originally Posted by grumblemarc
(Post 50112726)
Uh, wire it up?
Splice, direct fit, relay needed, relay, etc |
Custom work.....requires some knowledge of wiring schematics, soldering, and might need welding for the seat brackets.
I just skimmed through that and it tells you what needs to be done, you need to swap the seat pan, which means no more power seats......didn't you read that?
Originally Posted by tony_2018
(Post 50112886)
92-95 CIVIC: -Front- •92-97 Del Sol •94-01 Integra •96-00 Civic w/EG rails •97-01 Prelude w/EG rails •97-02 Accord Coupe w/EG rails •01-05 Civic*EM2 Only w/EG rails •01-03 CL w/EG rails*Requires 12v for heat feature They should bolt right on... no seat pan swapping required; only the rails from my EG seats.. didn't you read that? |
Originally Posted by Omega Blaze
(Post 50113306)
BOLT-ON.
Damn. You need help. eH. |
Originally Posted by eHMxhACk
(Post 50113309)
Lots of mudslinging in here. OP you're going to first have to figure out how the Accord seat rails are tied to the power seat feature, if at all. Something tells me they are, since the seats will need to move back and forth on the rails. If they are, can this feature be adapted to the EG rails? Get yourself the wiring diagrams for the Accord power seats, and grok them.
Some EGs in Japan had power seats, too. Here is the wiring diagram for them, this might come in handy. https://cimg6.ibsrv.net/gimg/honda-t...24e091c3e5.png https://cimg7.ibsrv.net/gimg/honda-t...231744d862.png |
(Post 50113306)
This chart will list all compatible vehicles for a proven and tested BOLT-ON combination. All other options will fall under the "Seat Pan Swap" category. Now let's put those myths and rumors to rest...
92-95 CIVIC: -Front- •92-97 Del Sol •94-01 Integra •96-00 Civic w/EG rails •97-01 Prelude w/EG rails •97-02 Accord Coupe w/EG rails •01-05 Civic*EM2 Only w/EG rails •01-03 CL w/EG rails*Requires 12v for heat feature They should bolt right on... no seat pan swapping required; only the rails from my EG seats.. didn't you read that? edit: well thanks for bolding the text. It states W/EG RAILS. So no you can't keep the accord rails because the motor is using them. |
Gets part brake for you car and use original wiring for seats get rails from Integra and weld in
Don't bump old, dead threads. Ever. Period. Especially when your information is wrong.
Originally Posted by Bundysauce
(Post 50591323)
