96 Civic Starter Issue
Hello. Can always turn to you guys for help. I went to start the car today and only got fuel pump primed. I left the key in the ignition in the run position and went under the hood and used a wire from the battery to the small post where the little black/white wire go and it fired right up. Have I pretty much isolated the issue to the ignition switch? Are there any other fuses or relays between the ignition switch and the black/white wire going to the starter solenoid? TIA
Thanks for the reply. It is a manual. I even went under that dash and manually pushed the switch for the clutch pedal and still no go. Do these switches go bad after a while?
The rubber has been missing for a while and I have been manually pressing to start by reaching up under dash. I plan to bridge that harness plug to see if it is a faulty clutch switch. If still no start it must be ignition switch?
austinramsay
Jun 16, 2014 09:16 AM
KimvdLinde
Jun 29, 2013 12:19 PM
zerovandez
Apr 1, 2011 01:05 PM
ThaSpitefulWun
Mar 1, 2005 09:35 AM
