DOHC ZC clutch option
Old Dec 13, 2014 | 06:33 PM
~sp33~'s Avatar
EFB055
Default DOHC ZC clutch option
Hi all,
So my Exedy HD clutch has started slipping now that i'm making a bit more power, and i'm trying to find a clutch with a higher torque rating (~200lb/ft at the wheels) and Exedy don't seem to have the option on their website.
I have an 88 (21 spline) transmission and would ideally like to run a 90-00 flywheel. I've seen a couple of clutch types out there that are a 21 spline count with a 212mm diameter, does that mean i can run the 90-00 flywheel? I'd like to run a lighter flywheel and i haven't found a lighter one to suit the 88 clutch.
This is the clutch i was looking at... (out of stock :/)
http://www.advancedclutch.com/hc7-hdss
It's an RT4wd transmission, so i can just easily find another D series trans to use instead.
Any ideas anyone?
Cheers
Old Dec 14, 2014 | 10:19 AM
jlicrx's Avatar
Default Re: DOHC ZC clutch option
this is the clutch that we use - 8200 rpm launch on 9.5 inch slicks - 11 lb. flywheel - no wheel spin - no problems
ACT XTSS Xtreme w Street Disc Clutch Kits | HorsepowerFreaks
Old Dec 14, 2014 | 10:52 AM
~sp33~'s Avatar
EFB055
Good to hear, thanks mate.
Old Dec 15, 2014 | 08:26 AM
24TEN's Avatar
PHANTOM MENACE
That's actually what I had back in the day. MAN I had to use the seat as leverage to push the clutch in before my calf muscle got built up and got used to it.
leondx
Apr 5, 2010 06:19 AM
prelude182
Mar 24, 2010 02:29 PM
impact_blu
Dec 30, 2005 04:07 PM
MintyDip
13
Jul 15, 2002 04:14 AM
