Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 V6 Auto drain plug, covered in sludge, normal? (pic)
Old Dec 12, 2014 | 08:07 AM
theLemur's Avatar
Default 2005 V6 Auto drain plug, covered in sludge, normal? (pic)
I just went to change the trans fluid @ 110k miles. I don't know the prior owners history so I am doing 3 flushes and the external filter. The bolt looked odd to me compared to pics I saw on here so I wanted to post it.
https://www.dropbox.com/s/p7xqxxc0x5...02.38.jpg?dl=0
Is this normal?
Old Dec 12, 2014 | 08:57 AM
lazlong's Avatar
Default Re: 2005 V6 Auto drain plug, covered in sludge, normal? (pic)
When ATF is that far gone it's best to leave it in there. At the most, I would just drain and fill once. When you put completely new ATF in a tranny with crap like that in it you're asking for it to fail.
Old Dec 12, 2014 | 09:12 AM
theLemur's Avatar
I feel like that's an old wives tail. Why specifically would new fluid cause it to fail?
Old Dec 12, 2014 | 09:26 AM
lazlong's Avatar
The new fluid will eat the coating right off the clutch packs.
I'm really surprised you don't already have problems with that much varnish in the tranny. Unless you can do it yourself you better start saving for that $3000 tranny rebuild.
Old Dec 12, 2014 | 09:30 AM
theLemur's Avatar
It shifts absolutely perfect right now. I did do two changes today, should i just go all in and do the third and the filter?
Old Dec 12, 2014 | 09:41 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The jury is still out on that. Though most professionals believe that the friction material loss from the clutch packs becomes suspended in the old fluid and aids in the transmissions operation.
I dont know how true this is or not,but I do know these facts:
1. Old, unchanged fluid breaks down chemically.
2. The old fluid DOES have clutch particles suspended in it.
3. I have experienced the "new fluid" trans failures on more than a few occasions when working on customers cars. Enough times that I now offer a disclaimer first.
With that said,your drain plug looks fairly normal for a Honda trans.
Old Dec 12, 2014 | 09:50 AM
theLemur's Avatar
Thanks for explaining. When you say it looks normal for a Honda trans, is that a good normal, or a very bad normal?
Old Dec 12, 2014 | 10:58 AM
theLemur's Avatar
I did the 3rd change, I'm all in at this point Filter to be done on Monday.
Old Dec 12, 2014 | 11:08 AM
BLKFLSH's Avatar
I don't think drain and fills will ever hurt a transmission. A Power flush, with a machine is something I would avoid. That's a lot of metal on the drain plug, but I would expect that much accumulation over 110k miles. I change out 3 quarts (DW-1) every 15k miles to keep it clean and fresh.
Old Dec 12, 2014 | 06:18 PM
lazlong's Avatar
Really? I've only seen that much varnish on trannies that were already bad.
I do a drain and fill once a year, which is 15-20K miles.
Projectsonic
13
Sep 19, 2012 10:30 AM
alexdc03
Mar 26, 2012 04:40 PM
JennyPooh
40
Nov 4, 2010 11:17 PM
mark_is_gay
Apr 14, 2006 04:49 PM
slowd16z6
Dec 12, 2003 01:51 PM
