Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Any tips for changing the harmonic balancer?
Old Dec 10, 2014 | 07:00 PM
hometheaterman's Avatar
Default Any tips for changing the harmonic balancer?
I'm considering changing the harmonic balancer on my 06 Accord V6, although I'm not quite sure I'm to that stage yet. I'm still trying to troubleshoot the noise I'm getting. I have an extra pulley, but I have some questions. I've never tried to change one and I'm aware of the crank bolt removal issues. If you get it off, I always thought you should mark it to make sure it went back on in the same spot, but if you're changing it, what do you do? Do you need to make sure it goes on exactly the same or does it not matter? Any tips for this job?
Old Dec 11, 2014 | 05:44 AM
MSchu's Avatar
My Name is Nobody
Default Re: Any tips for changing the harmonic balancer?
It's a harmonic balancer... why would it matter to put it on in the same position?
Old Dec 11, 2014 | 10:31 AM
94vtecmn's Avatar
There is a key on the crank, it can only go on one way.
Old Dec 11, 2014 | 10:36 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
+1
Old Dec 11, 2014 | 01:41 PM
BLKFLSH's Avatar
After you get the crank bolt off, the pulley should come off easy, no puller needed.
Old Dec 11, 2014 | 06:07 PM
Thanks guys. I appreciate the help. If I end up having to change it I'm hoping my Ingersol Rand impact wrench can get it off. It sounds like it can be a pain.
Old Dec 11, 2014 | 06:56 PM
BLKFLSH's Avatar
I had a brand new 1/2" drive IR impact gun rated at 550 lbft. and it didn't budge the crank pulley bolt with an hour or more of trying. I had to borrow a 1" drive impact, and that did the trick with one blip of the trigger. If your impact isn't more powerful, and your crank bolt is as tight as mine was, you're going to have a problem.
Shownutz
Oct 15, 2014 11:19 PM
numbinside
Feb 10, 2012 03:51 PM
eM1<3
48
Sep 10, 2009 02:19 AM
y2kferari
Dec 26, 2008 09:57 AM
DC4 Rasta
Aug 27, 2007 12:50 PM
