2003 Accord Right Turn Signals Not Working
Hi all, I'm having this issue on my son's 03 Accord. The right turn signals are not working. I've performed the diagnostic steps outlined in the thread for same issue on left-hand side, but jumped terminals 3 & 6 for the right signal. When I do so, the right turn signal indicator light illuminates on the dash, but still no right signal or right side hazards. I tried plugging in a new relay for kicks and giggles, but it was not that. Any ideas? The bulbs are good and so are the grounds (as I have parking lights).
If it's only the front or back then it's the ground for that light. If it's both the front and back then I'm thinking the hazard switch is bad, the system runs through that switch.
FYI- Just because you have ground for one light doesn't mean you have ground for another. They're all separate wires until they ground at the chassis.
accordlx1998
Apr 22, 2005 08:24 PM
