Ek driver side floor soaking wet
Old Dec 8, 2014 | 12:55 PM
Azavala's Avatar
Default Ek driver side floor soaking wet
So I have a 98 ek coupe and I live in washington so it rains often but went to move my floor Mat around the the other day and I found my carpet was soaking wet but it's only at the base of the car like by the pedals it isn't wet at all. Also under my drive side carpet and the back seat carpet on driver side is wet and has a small puddle. But the passenger side is perfectly fine. Need help? A place to start or something? Thank you
Old Dec 8, 2014 | 05:29 PM
rockycat's Avatar
Default Re: Ek driver side floor soaking wet
Maybe the sun roof drains are blocked on the left side.
Old Dec 9, 2014 | 05:31 AM
Frank_ej6's Avatar
I have the same problem on my 97 civic dx 4 dr...my driver side is soaking wet...what should i check?
Old Dec 9, 2014 | 05:51 AM
tony_2018's Avatar
Fish Twig
Pull apart headliner, driver side pillar, and driver side kick panel and start locating the leak.
Old Dec 9, 2014 | 06:52 AM
koffeedc2's Avatar
check the heater core, i had the same problem a while back
Old Dec 9, 2014 | 07:08 AM
rockycat's Avatar
having to refill radiator often, heater core maybe. Seat and one side wet , sunroof drain clogged and drain pan overflow.
Old Dec 9, 2014 | 08:28 PM
Azavala's Avatar
So I ended up ripping it apart today and found that it was the drain tube for my sun roof and it has falling out of the drain part. With that being said the 2 tubes are super loose when put together any tips on how to make them stick back together ?
Old Dec 9, 2014 | 08:52 PM
tony_2018's Avatar
Fish Twig
Pictures.
Old Dec 10, 2014 | 05:58 AM
EsotericImage's Avatar
Retired Moderator
jb weld
Old Dec 11, 2014 | 06:14 AM
Azavala's Avatar
I got it all fixed and everything thanks
skaternak
10
Jan 28, 2010 05:11 PM
twilliams83
Jan 21, 2010 01:37 PM
DCSportEJ1Civic
Sep 10, 2007 11:48 AM
Leb_CRX
38
Feb 4, 2005 11:34 AM
DevinW
Nov 19, 2002 08:38 PM
