96 coup shudders
Old Dec 7, 2014 | 06:15 PM
rockycat's Avatar
Default 96 coup shudders
96 vtec auto, mode header and cold air intake. Problem cold left turn and heavy foot and slight up hill there is a shudder. Right turn and down hill no shudder. Both axles are replaced and the left is 6 to 9 months older. Good compression, good dist. cap and rotor, new plugs. As car is driven the shutter gets less and less but does not go away.
Old Dec 8, 2014 | 11:39 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 96 coup shudders
I'm having trouble understanding what you mean by shudder. Like a mechanical sound or something rubbing on something else? Vibrational?
Old Dec 8, 2014 | 01:26 PM
rockycat's Avatar
Not a sound and not rubbing. A shudder like a torque converter shudder at hiway speeds. On taking off from a start and turning left.
Maybe should be called a shutter and not a shudder.
Old Dec 10, 2014 | 01:44 PM
rockycat's Avatar
There may be a bump waiting period but I need the car and am afraid to drive it. If it is transmission then it is on its way out.Thinking axle but suspect tranny.
Old Dec 10, 2014 | 01:47 PM
Former User's Avatar
Sounds like a suspension issue if it only shudders when turning.
Old Dec 10, 2014 | 05:37 PM
rockycat's Avatar
After spending the day under the car I see nothing wrong with the suspension so leaning towards a axle.
Old Feb 10, 2015 | 03:32 PM
rockycat's Avatar
Update. Weather good so changed the left axle. Binding under load and in a left turn causing wheel hop that felt like driving on a cobble stone road.
Old Feb 10, 2015 | 03:37 PM
NotARaCist's Avatar
I never narc'd on nobody!
axle binding causing wheel hop? So...how "tucked" are you?
Old Feb 10, 2015 | 04:38 PM
rockycat's Avatar
"tucked"?
Old Feb 10, 2015 | 04:56 PM
Originally Posted by rockycat
"tucked"?
Hey, stop cussing!
Old Feb 10, 2015 | 05:00 PM
rockycat's Avatar
Just wandering what not a racist meant by "tucked"
Old Feb 10, 2015 | 05:25 PM
Nave43's Avatar
I guessing hes asking if your car is lowered and or running camber. If so how much so?
Old Feb 10, 2015 | 05:29 PM
rockycat's Avatar
No mods to the suspension. Stock height.
Old Feb 10, 2015 | 05:32 PM
Nave43's Avatar
Did you torque everything to spec? Was the axle you swapped in known to be good?
Old Feb 10, 2015 | 05:38 PM
rockycat's Avatar
The axle had 1/4 or less there about of free play on the outside cv. The axle was about 2 1/2 years and a "rebuilt".
Old Feb 10, 2015 | 09:37 PM
NotARaCist's Avatar
If the axle was binding to the point of causing wheel hop, and your car isn't lowered, then you got a REALLY shitty axle, and I'm surprised you didn't notice this until 2 and a half years later. Something just doesn't add up.
Old Feb 11, 2015 | 07:02 AM
rockycat's Avatar
Shitty axle yes. Did not start until about 6 months ago. Did you read "rebuilt"?
Old Feb 11, 2015 | 07:27 AM
turbohatch96y7's Avatar
Easy there, guy
Old Feb 11, 2015 | 07:58 AM
Nave43's Avatar
Not trying to troll Rocky Cat but not a Racist is right. Something in this story doesn't add up. Are you saying to old axle was a 2 1/2 year old rebuild? or the one you swapped in?
Don't you have a different problem now than when you started? I thought you had a shudder, now you have wheel hop? Please for all our sake please be more clear in future posts.
Old Feb 11, 2015 | 08:21 AM
rockycat's Avatar
As I posted it felt like driving on a cobble stone road. That felt like a shudder to me and had I not watched the car turning in a circle(wife driving) I would still be looking. Don't see where I'm the bad guy here but if I said some to offend some one o'well. The faulty "rebuilt" axle was 2 1/2 years old and started just a few month ago. May have started longer ago but this old body didn't notice until a few months ago.
94 IntegraLS
Apr 23, 2013 08:32 AM
KSWEST
14
Jan 13, 2009 10:19 PM
dang_erous
Apr 25, 2007 11:21 PM
YoungKadafi
Suspension & Brakes
Sep 30, 2006 06:43 AM
