DRL Light On
Hey guys, the DRL light is on in my 2004 Honda Civic. I know it's not the module because I soldered it already and even used another one to see if that was the problem. Any ideas on what it could be? I checked the fuses under the dash too. Thanks.
‘‘Daytime Running Lights’’ Indicator - Canadian models only
"This indicator comes on when you turn the ignition switch to ON (II) with the headlight switch off and the parking brake set. It should go off if you turn on the headlights or release
the parking brake. If it comes on at any other time, it means there is a problem with the DRL. There may also be a problem with the high beam headlights."
1. Does your daytime running lights function properly; i.e., are the high beams at reduced brightness in DRL mode? In DRL mode, the high beam headlights operate in series and act as resistors to reduce the voltage to the headlights.
2. Turn on the high beams, are they at full brightness?
3. Have you tried new high beam bulbs?
You mean the DRL indicator is still on when you release the parking brake, right?
Are the the daytime running lights on at reduced brightness when in DRL mode?
Yes, the bulbs are sometimes the issue for the DRL indicator staying on. I post on another forum and that has been the case a couple of times for some Accords.
Yes the DRL indicator is still on when I release the parking brake. It usually makes a noise when you release the parking brake and that's when the lights turn on, but on this car it doesn't make that clicking noise. Do you know what I'm talking about?
The daytime running lights are not on at reduced brightness when in DRL mode. They are off.
But yah, I will swap the bulbs and let you know. Thanks.
misterix
Jul 6, 2009 07:31 PM
