92 civic HB with built GSR - HESITATION WHEN I SHIFT
Ok so i looked around to find a thread about what's happening to my car could not find one. OK so my car is a 92 civic HB with a built GSR. With cams valve train and jdm itr pistons with all the bolt ons you would see in a normal set up. On s300.
So my car is hesitation/misfiring when I shift at high RPM when I engage my clutch going into the next gear. For the first second of accelerating in the next gear it hesitates. when I shift fast at low RPMs it's fine but not at high RPM. and it pulls nice and hard from 1500 RPM to 8800 RPM
You might try TPS settings. Make it think 75% throttle is 100%. Unless the car has run great before on the current tune and this problem is new.
