Zeitronixs ZT-2
Old Dec 6, 2014 | 08:46 PM
Treyschls's Avatar
Default Zeitronixs ZT-2
hello what do I wire the purple wire to..?
Old Dec 7, 2014 | 06:14 AM
rudebwoy's Avatar
Default Re: Zeitronixs ZT-2
d14
Old Dec 7, 2014 | 06:20 AM
rudebwoy's Avatar
BTW your car's info and ecu would have probably got you more answers, and quicker. but because I am not a dick, and I use the ZT2 wideband plus I think its the greatest.
I am running Hondata and I connebted the purple wire to pin D14 to trick my OBD1 ECU that my stock O2 sensor is still connected
Old Dec 7, 2014 | 11:22 AM
Treyschls's Avatar
Sweet! Man thanks I wasnt getting to many answer...
Aince yoir familiar with it can you explain why I would want to you the purple wires feature. Why simulate an o2 and why signal from the 2nd O2 signal wire (D14)
Old Dec 7, 2014 | 12:24 PM
rudebwoy's Avatar
http://www.zeitronix.com/installatio...structions.pdf
why do you need a second O2 sensor? if you are still using the stock ECU there is no need for a wideband because you can't make any changes to the ECU anyways.
D14 was me assuming that you are using a OBD1 programmable ECU like Hondata s300
the white can also be used, but the white wire allows the ECU to see the actual A/F the wideband is seeing.
the purple is just the stock signal as if you are using the OEM sensor
Old Dec 11, 2014 | 07:49 PM
Treyschls's Avatar
thanks! purple is for stock signal. that's what I needed to hear!
crxb16a90
May 6, 2016 11:19 AM
5thGenFanatic
Dec 30, 2009 07:55 PM
sanfriz
Mar 26, 2006 11:06 PM
duceduce22
Mar 24, 2006 03:46 PM
