Timming issue
Old Dec 6, 2014 | 02:05 AM
armangill55's Avatar
Default Timming issue
Hey ht i need help. so i had b18b short block assembled and was with oem main caps. now i have arp and i had trq down to 80ft-lb as arp site said and in the right sequence... HOWEVER crank won't rotate it feels as if its way too tight! ANY HELP OR BUMP would be appreciated thanks
Old Dec 6, 2014 | 08:30 AM
Default Re: Timming issue
Old Dec 6, 2014 | 03:46 PM
hardcore97's Avatar
did it rotate before? get some green plastigauge and check your clearances
Old Dec 6, 2014 | 03:58 PM
Fliptard's Avatar
When you use ARP studs for mains, you need to have the mains line hones with the arp's torqued.
Or use a bearing with the next bigger clearance. which isn't recommended.
Old Dec 8, 2014 | 03:48 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Same caps that came with the block? Different caps wont work,they need to be matched to the block.
Old Dec 10, 2014 | 06:36 AM
hardcore97's Avatar
you can use different caps, just has to go to the machine shop
Godspeed07
Nov 13, 2007 06:38 PM
tshracing
Feb 6, 2007 04:55 PM
poorman's type-r
Apr 13, 2006 07:42 PM
flounder940
Sep 24, 2004 03:51 AM
masterk0ns
Sep 15, 2002 04:35 PM
