Car won't start need help
So I was in the process of fixing something and so I pulled my fuse box and all the wires to move them. I plugged everything in and was having issues so I went through and replaced the alternator wire to the fuse box plus the wire lead from the starter to the fuse box now I'm not getting any power when I turn the key Nothing lights up on the dash board it is completely dead nothing at all please some help
__________________
I Rep The Bay Area in my Daily Driven RHD Ej6 Coupe
__________________
My first check would be ground wires. I know when I did a rebuild on my b18 in my EJ6, I had the same issue when I plugged it back in to the car because of some not-so-great ground wires. Double check to make sure all your connections are clean and secure.
https://honda-tech.com/engine-manage...start-3231696/
Seriously?? You can post your car information there but you don't want to do it here?
I have a 98 Honda Civic Dx coupe with a 98 LS Acura Integra motor stock even ECU obd 2 engine harness is a rewired stock 98 civic dx converted by Ryan of Rywire to run 98 obd 2 integra ecu but have added a push button start that's wired in outside the harness
91sedan_kid
Jan 19, 2025 09:13 PM
rhd_ej coupe
Feb 1, 2008 09:56 AM
