NEED HELP!! small ignition problem
a week ago my car started up fine. i did a small wire tuck and had to extend about 10 wired off the engine harness. i soldered all my wires i matched the right wires and did not cross any of them. i checked and doubled checked. i reconnected all my wires and rehooked up my battery and tried to start my car to move it and noticed that all of my lights and everything works but when i turned the key my started does not start. i checked the fuses all my connection and turned the key again and it still wont start it wont do anything. i checked the starter signal wire with a light tester, and knowtisted nothing, no power. I went to the fuse box checked the fuse its not blown, i light tested it, no power. I dont know what to look at next!! Someone please help!!
Re: NEED HELP!! small ignition problem (rhd_ej coupe)
honestly check your connections (and splices), you may need to get a wiring diagram for this. If theres no power going to the fusebox for the starter after doing a wire tuck, you messed something up somewhere down the line good luck
Re: NEED HELP!! small ignition problem (Remington)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Remington »</TD></TR><TR><TD CLASS="quote">honestly check your connections (and splices), you may need to get a wiring diagram for this. If theres no power going to the fusebox for the starter after doing a wire tuck, you messed something up somewhere down the line good luck</TD></TR></TABLE>
x2 when doing wire tuck take ur time do it once do it right...u must been messed something up somewhere now u going back to square1 good luck.......
91sedan_kid
08-11-2023 11:38 PM
immrtaltchnq
09-22-2008 05:36 PM
iamtehwinnar
04-24-2007 05:22 PM
