98 civic won't start
So I was in the process of fixing something and so I pulled my fuse box and all the wires to move them. I plugged everything in and was having issues so I went through and replaced the alternator wire to the fuse box plus the wire lead from the starter to the fuse box now I'm not getting any power when I turn the key Nothing lights up on the dash board it is completely dead nothing at all please some help
Fuse #41 (80 amp) powers the entire under hood fuse panel, fuse #42 (40 amp) powers the ignition switch. Which fuse panel were you working on? Verify power on the two referenced fuses. #41 comes directly from the battery, test with some kind of load (1156 bulb configured as a tester). Don't depend on the look of a fuse verify that power is present on both sides and will light the above mentioned tester.
AkA_JackRisom
Feb 27, 2006 09:28 PM
