Noticeable difference in driving impressions from a '97 and '98+ ITR?
Old Dec 5, 2014 | 05:30 AM
JDM_rolex's Avatar
Default Noticeable difference in driving impressions from a '97 and '98+ ITR?
I have been interested in a Type R for a long time but have not found the right one.
I just wanted your review of any noticeable driving differences between the 97 and the 98+ ITRs. I don't mean the exterior changes as I understand Honda made some changes there but rather the driving impression. I also understand that on paper one is better than the other but that is beside the point.
I also want to reiterate that there may be mechanical changes to the engine and performance of the vehicle but over all, are they 2 identical cars with one being just more refined? Or is one car rough around the edges but more of a race car than the other.Do the '97 and '98+ ITR drive the same? Does one handle better than the other? If so which one? And lastly why did you select your Type R?
Thanks!
Old Dec 5, 2014 | 06:37 AM
Xian's Avatar
Default Re: Noticeable difference in driving impressions from a '97 and '98+ ITR?
I've owned a 97 and two 01's... they're effectively the same thing, IMO.
Yes, I know the later (00/01 IIRC) cars had a different cam, there is the OBD2a vs. OBD2b thing, standard rear wiper, standard AC, different front and rear bumper covers, different shift ****, different interior faux CF trim, etc but none of that really impacts how the car drives. Same springs/shocks/bars/brakes/diff/tranny/etc...
Old Dec 5, 2014 | 06:49 AM
Todd00's Avatar
I said I don't want a title!
OP, where did you come up with this info at? I suggest you google or check some online resources as there are very few changes between the 97-01 model years.
Old Dec 5, 2014 | 08:51 AM
DC2888's Avatar
assuming both are kept in good condition, they should drive the same
Old Dec 5, 2014 | 09:19 AM
JDM_rolex's Avatar
Thanks guys!
Are you confused with the second paragraph of the original post? I understand that there are differences between the JDM and USDM versions.
Old Dec 5, 2014 | 11:12 AM
Todd00's Avatar
Originally Posted by JDM_rolex
Thanks guys!
What? Where did you mention anything about "JDM" cars? What are you talking about, exactly? Perhaps you should re-read your original post.
Old Dec 5, 2014 | 01:13 PM
Ultraspeed DC2's Avatar
Aren't then steering rack ratios different?
Old Dec 5, 2014 | 05:55 PM
typer_696's Avatar
These are the specs for an 01. USDM market. Jdm is a whole different setup.
Engine Type
1.8-liter, 16-valve DOHC VTEC' in-line 4-cylinder
Horsepower, SAE Net
195 hp @ 8000 rpm
Torque, SAE Net
130 lb-ft @ 7500 rpm
Redline
8400 rpm
Fuel Cutoff
8500 rpm
VTEC Switchover
5700 rpm
Bore & Stroke
3.19 in x 3.43 in (81 mm x 87.2 mm)
Displacement
110 cu in (1797 cc)
Compression Ratio
10.6 : 1
Induction System
Programmed Fuel Injection (PGM-FI) with single-port intake manifold
Valvetrain
Variable Valve Timing and Lift Electronic Control (VTEC) 4-valves-per-cylinder, belt-driven, dual overhead camshaft
Engine Block
Aluminum alloy with cast-in iron cylinder liners
Cylinder Head
Aluminum alloy
Emission Control
3-way catalytic converter / EACV
Ignition System
Electronic ignition with knock sensor
Alternator
85 amp max
Battery
12V, maintenance-free
Recommended Fuel
Premium Unleaded, 91 octane
Layout
Transverse-mounted, front engine, front-wheel-drive with equal-length drive shafts and limited slip differential
Transmission
5-speed manual
Ratios (:1)1st
3.230
2nd
2.105
3rd
1.458
4th
1.107
5th
0.848
Reverse
3.000
Final
4.400
CHASSIS
Body Type
All-steel unit body
Front Suspension
Independent double-wishbone with coil springs and stabilizer bar
Rear Suspension
Independent double-wishbone with trailing link, coil springs and stabilizer bar
Shock Absorbers
Gas-pressurized with Acura Progressive Valve technology, front and rear
Stabilizer Bars
Front
0.94 in.
(24 mm) diameter, ball joint type
Rear
0.87 in.
(22 mm) diameter
Steering Type
Variable, power-assisted, rack-and-pinion with rotary-valve steering gear
Steering Ratio
15.7:1
Steering Wheel Turns (lock to lock)
2.85
Turning Circle (curb to curb)
34.8 ft (10.6 m)
Wheels
15 x 6.0 JJ cast-aluminum alloy
Tires
195/55R15 84V Bridgestone RE010
Braking System
Dual-diagonal, power-assisted, 4-wheel disc brakes with ABS
Front Discs
Ventilated, 11.1 in (282 mm) diameter; 0.83 in (21 mm) rotor thickness
Rear Discs
Solid, 10.2 in (260 mm) diameter; 0.35 in (9 mm) rotor thickness
Total Swept Area
Front: 1478 cm2 Rear: 1095 cm2
Anti-Lock Braking System (ABS)
3-channel system with 4 wheel speed sensors and electric/hydraulic control unit
Old Dec 5, 2014 | 06:05 PM
typer_696's Avatar
Here is a 98 steering rack ratio is different.
Horsepower, SAE net
195 hp @ 8000 rpm
Torque, SAE net
130 lbs-ft @ 7500 rpm
Redline
8400 rpm
Fuel Cutoff
8500 rpm
VTEC Switchover
5700 rpm
Bore & Stroke
3.19 in x 3.43 in
(81 mm x 87.2 mm)
Displacement
110 cu in (1797 cc)
Compression Ratio
10.6:1
Induction System
Valvetrain
4 valves per cylinder, dual overhead camshafts driven by a single belt with Variable Valve Timing and Lift Electronic Control (VTEC)
Engine Block
Cylinder Head
Aluminum alloy
Emission Control
Ignition System
Alternator
85 amp. max.
Battery
Recommended Fuel
Premium unleaded, 91 octane
Body Type
All-steel unit body
Front Suspension
Independent double-wishbone with coil springs, stabilizer bar
Rear Suspension
Shock Absorbers
Gas-pressurized with Honda Progressive Valve, front and rear
Stabilizer Bars
Front
Ball joint type, 0.94 in (24 mm) diameter
Rear
0.87 in (22 mm) diameter
Steering Type
Variable power-assisted, rack-and-pinion with rotary-valve steering gear
Steering Ratio
16.1:1
Steering Wheel Turns, lock-to-lock
2.98
Turning Circle
34.8 ft
(10.6 m)
Wheels
6.0 JJ x 15 cast-aluminum alloy
Tires
Bridgestone RE010 195/55 R15 84V
Braking System
Dual diagonal, power-assisted,
Front Discs
Ventilated, 11.1 in (282 mm) diameter,
Rear Discs
10.2 in (260 mm) diameter,
Swept Area
Front: 1478 cm2
Rear: 1095 cm2
Parking Brake
Disc type, mechanically actuated on rear wheels
Anti-lock Braking System (ABS)
3-channel system with 4 wheel-speed sensors and electronic/hydraulic control unit
POWERTRAIN
Type
Transverse-mounted front engine/front-wheel drive with equal-length driveshafts
Transmissions
Ratios (:1)
1st
3.230
2nd
2.105
3rd
1.458
4th
1.107
5th
0.848
Reverse
3.000
Final Drive
4.400
CAPACITIES
Old Dec 5, 2014 | 08:35 PM
coolhandluke's Avatar
I have owned and tracked two 98's, one 01', and now 97'. I never noticed a difference in the steering racks. The bigger difference is removing PS.
Old Dec 6, 2014 | 07:43 AM
pennies_hatchie's Avatar
ive had a 97, 98, 00, 01 and my butt dyno tells me all were the same minus the 01 as it had the intake cam.
Old Dec 6, 2014 | 09:01 AM
itr#1334's Avatar
00-01 both had the same intake cam.
MNsnowdaboy
May 17, 2004 02:37 PM
It's James
Jan 9, 2003 08:28 AM
typRpwr1161
Jul 17, 2002 08:44 PM
Cosworth
Jun 14, 2002 09:53 AM
Vtec195hpR
Dec 6, 2001 02:32 AM
