98 civic with d16y7 - what cause loss of cylinder compression?
Hello, I am new to Honda and I have a 98 civic with the base d16y7 I am wondering what normally will cause a cylinder to lose compression. cylinder one, two, and four are reading 150 but cylinder three isn't even hitting 20. there is no bottom end knock nor top end noise in addition there is no metal shavings in the oil. I took the cam gear cover off to see if someone had replaced the timing belt and set it off a tooth the belt is old and warn. I then pulled the valve cover and neither the intake or exhaust valves on cylinder three are stuck. what would be everyone's next step be?
ok I did the leak down test. got cylinder 3 at tdc applied air to the cylinder no air came out of the throttle body no air came out of the radiator no air came out of the dipstick tube nor did it come out of the exhaust. however air was releasing slightly out of cylinder one and a bit more out of cylinder 2 spark plug holes. would bad timing cause this? as I said before the timing belt doesn't look "new" but you can still read the writing on it and the rest of the belts (serp belt, ac belt, power steering belt) all look the same age as the timing belt but u can still read the part number on all belt. maybe previous owner did timing belt and it off a tooth?
I have the top belt cover off the they all seem to be right on mark but I do not have the bottom cover off to the the bottom marks.
I was not aware of the third mark for the crank I will go check that now. if they are lined up as they should what do u think the problem could then be?
ok so I got tdc1 and all marks on cam and crank match up perfectly! im stumped I did a leak down double check and this time cylinder one was fine cylinder two couldn't hold the pressure and took it off tdc and leaked out the intake cylinder three held the pressure and leaked out cylinder one and two and cylinder 4 couldn't hold the pressure and leaked out the intake... warped head...?
****... I did not hold WOT but I unhooked the injectors to stop fuel so it wouldn't fire. could this be the confusion whats the reason behind WOT? I feel like a dumb *** now haha.
there is no oil in the motor right now I will do it at a later time and get back to you please keep an eye on this thread thank you for all your help
I did another compression test with WOT this time the numbers were higher towards the 180's but cylinder three was significantly lower at a high of 60
These^ are obviously spurious results. Install spark plugs in all but cylinder 3 and redo the leakdown test for cylinder 3.
Ensure proper engine oil level, remove ecu fuse from engine bay fusebox, only remove the spark plug for the cylinder you're doing the compression test on, screw in compression tester, step on gas pedal and crank car.
JudahDamian
Dec 4, 2018 07:30 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
imgonnalie2u
Jan 11, 2005 08:05 AM
